Old 07-01-2003, 03:25 PM
room217 room217 is offline
won't start / low voltage @ fuel pump
Hey everybody. I need a little help here.
Just the other morning my 93 Tallon wouldn't start. Turns over fine and even cought a couple of times but stalled. Seems like it's out of gas, but it's not.
I've listened for the fuel pump at ignition and heard nothing.
Then I used the fuel pump jumper connection and I still didn't hear anything.
So I checked the EFI control relay and it WAS reading wrong so I bought a new one, but it reads the same as the old one and ... it didn't work.
I've checked the voltage at the fuel pump and it reads .02 volts, so I'm pretty sure it's not the fuel pump...
Must be a short in the wires??
Any Ideas?
Thanks.
Old 07-10-2003, 05:41 AM
kjewer1 kjewer1 is offline
AF - Advisor
Is your pump rewired? Or stock wire.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-10-2003, 10:33 AM
hey Kevin,
Stock, I think. She is 80 miles away from 200k, rebuilt @180k.
I did get the fuel pump to start using the jumper (I screwed up the 1st time).
I've checked the wiring, it's good.
I actually think it's the ecu. I found a capacitor that 'took a shit' using this website.
I'm going to take a shot at replacing those 3 capacitors tomarrow.
Wish me luck!
And Thanks for the input.
Old 07-10-2003, 03:57 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Check to make sure the MPI relay is good too.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 07-10-2003, 05:17 PM
AF - Advisor
With your mileage I'm surpised the caps lasted this long! Hopefully thats it. While you're in there check to be sure the stuff that leaked out didnt ruin the board, thats fairly common when they have been bad for a while.
Kevin Jewer
92 Lumina Won't Start ICM Voltage Brndo Lumina 9 05-02-2010 11:37 PM
low voltage fuel pump relay scottinachevy C/K 1 10-26-2009 07:34 PM
won't start after new fuel pump installation susansbostons Silverado 5 09-29-2004 06:56 PM
1996 GMC won't start distrib/or fuel pump? duke69 Sierra 5 04-18-2004 09:17 PM
