Go Back   Automotive Forums Car Chat > Mazda > MX-6
Old 02-06-2004, 09:29 PM
vendaz vendaz is offline
Engine 'convulsing' below 1K RPM
Hey people,
I have a '90 MX6 that just this week started acting up -- whenever the engine is running and the RPM gauge is below 1,000 RPM, the engine starts revving up and down really violently. I have to hold the brake and gas pedal above 1,000 to keep it from doing it, and even then it shudders.
Could this be a gas line problem? It drives fine when above 1,000 RPM.
Old 02-07-2004, 01:21 AM
ricci ricci is offline
Send a message via Yahoo to ricci
Re: Engine 'convulsing' below 1K RPM
i had the same problem...quick fix, tap the EGR solenoid valve with a hammer the engine will go back to the normal idle speed.
another way...spend $250 in a new egr valve
Old 02-07-2004, 08:46 AM
Thanks for that, ricci. I hope it works!
Old 02-07-2004, 07:43 PM
RoxysBrian RoxysBrian is offline
I had the same problem and had to replace the hose running between my air flow sensor and the throttle body. You might have the same problem. Check the hose and see if there are any holes or cracks in it, if there are you can do a quick fix by putting duct tape on it, but I would replace it. I had to buy one directly from the Mazda dealership but it only cost about $65.
Old 02-08-2004, 10:30 AM
RoxysBrian,
Thanks for the suggestion. Where is that hose, specifically?
Old 02-08-2004, 02:05 PM
Re: Re: Engine 'convulsing' below 1K RPM
Originally Posted by vendaz
RoxysBrian,
Instead of explaining it out, I just took a picture of my engine and drew a red box around the hose you need to check. http://myweb.cableone.net/ebruff/smi...20engine-1.jpg
Old 02-09-2004, 02:27 PM
Yes, that helps a great deal more than explaining it out. Thanks!
Old 02-11-2004, 09:58 PM
RoxysBrian,
You take the prize, my friend -- exactly right. $35 for the part.
Old 02-12-2004, 08:15 PM
RoxysBrian,
You got out cheap. That hose new from the Mazda dealer cost me $65. Glad to be of help.
Loud Engine Knock below 2,500 RPM claudiovarga Rodeo | Passport | MU 13 05-03-2008 07:11 AM
J30 Rough engine at 2K RPM?? thenewkid64 Cedric | M45 | J30 | Gloria 5 09-01-2004 11:42 AM
Engine Hesitation Low RPM intellivid Accord/TSX/Accord Hybrid 13 08-26-2004 12:47 PM
Engine lags @ 4500 RPM in 2nd!!! 2xKlutch Off-Topic 11 04-28-2004 01:06 PM
Engine 'convulsing' below 1k RPM vendaz Engineering/ Technical 1 02-07-2004 10:06 AM
