Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-01-2008, 07:17 PM
claudiovarga claudiovarga is offline
Loud Engine Knock below 2,500 RPM
1995.5 rodeo, runs fine, good power, etc.
Developed a rather loud engine knock at idle and up to 2,500 rpm.
The noise stops above 2,500 and everything sounds fine.
Sounds like a loud clicking sound, can't tell if it's the top or bottom.
One (none Isuzu) mechanic didn't know anything and just said the motor was dead, but I'm not buying it. miles are 99K
Any advice?
Old 05-01-2008, 07:40 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Re: Loud Engine Knock below 2,500 RPM
Any advice?
yes this more than not misdiagnosed and you are right not to buy it.
this is the classic symptom for
the timing belt tensioner, which keeps the timing belt tensioned correctly and when it goes (it's a small selfcontained hydraulic dampner), whe it goes the timing belt tensioner pulley "paddle" starts slapping into that tensioner and *****causes the racket often misdiagnosed as a thrown rod. when the rpms get ~2500rpm +/- the belt calms down and the racket disappears.
the fix:
*replace timing belt
**replace timing belt tensioner
***replace water pump (it's driven by the timing belt and the belt work has to be done all over again to replace, probably sooner than later.
****replace timing belt tensioner *pulley* only after inspection turns up an iffy bearing
get the parts from isuzu. it's not worth the chance on ebay stuff for a job like this
this can be a doityourself project if you are up for it and have the correct info on how to do it. there's plenty of good writeups out there
and then there is the isuzu factory service manuals from www.helminc.com
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 05-01-2008, 08:11 PM
FL 3.2L FL 3.2L is offline
Guessing the timing belt/tensioner/water pump haven't been done yet?
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 05-01-2008, 08:42 PM
I had the timing belt/water pump done 40K miles ago, not recently.
I will have Isuzu shop where I bought take a look.
Assuming the tensioner is the cause, is there any potential for MAJOR damage done by my driving it until I can get it in for service in the next few days?
Thanks!
Old 05-01-2008, 08:53 PM
Could skip timing and damage valves. I wouldn't drive it. Did they not change the tensioner?
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 05-01-2008, 08:57 PM
http://www.automotiveforums.com/vbulletin/t325554.html
Again, I wouldn't drive it...
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 05-01-2008, 09:11 PM
Don't know if tensioner was changed with water pump, etc.
It was a long time ago at 65k miles.
I will only drive it straight to the Isuzu shop and have them look at it.
Thanks again.
Old 05-01-2008, 11:55 PM
Ramblin Fever Ramblin Fever is offline
x3 timing belt tensioner...engine is FAR from dead, i have twice as many miles as you.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-02-2008, 12:41 AM
trooperbc's Avatar
and PLZEEE no more of this stupid baiting about the isuzu 3.2L v6 being an interference engine. it is not. this has been worked over here and this constant misinformation just misleads those that don't know
here DA WORD: DA FINAL WORD >
ALL ISUZU V6 ENGS ARE NON INTERFERENCE ENGS FROM 92TROOPER ALL THE WAY TO 2002 AND THE RODEOS 93 THRU THE 2003 MODEL YEAR,
3.2 3.5 DOHC AND SOHC
2004 DI 3.5 IS AN INTERFERENCE ENG
NO EXCEPTIONS JERRY
http://forum.planetisuzoo.com/viewto...?p=98391#98391
this means it's non-interference period. this means valves will not be damaged by mis-timing. this means that the piston can not hit the valves, nor the valves hit the piston.
comeon....
//bc
Old 05-02-2008, 03:13 PM
So you'd have no problem driving it? I'd say not interfering while turning by hand is very different from a running situation. It'd be foolish not to treat almost any engine as if it were interference. There are posts on this forum about valve damage and timing belt breakage.
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 05-02-2008, 06:00 PM
amigo-2k amigo-2k is offline
Isuzu Guy
[quote=FL 3.2L There are posts on this forum about valve damage and timing belt breakage.[/QUOTE]
On a 2.2L GM engine commonly in the Rodeo and Amigo, but I can't say I have ever remember anyone with valve damage on a 3.2/3.5L
I can remember a post from 2eye in which he said he had his timing belt off and tried to start the truck for the heck of it and it did no damage.
And I think there was recent post here from a guy with a 98 (3.2L) that his belt snapped at 205k and he replaced it and went on his way.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 05-02-2008, 06:09 PM
Just saying it is prudent not to drive it as is. Search threads by wildlysmiley and redbug.
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 05-03-2008, 12:22 AM
typing w/broken hand...sorry for mishaps.
i do remembr one 3.2l owner stating his belt had broke and he believed it damaged his valves, but don't remember if he ever finished his thread.
i can with experience say that my belt jumped a tooth, tb tensioner went out causing engine to sound horrible nough that i refused to even put it in gear to drive it. called for a flatbed to come get her, i wouldn't have dreamed driving it the 25 miles to the shop that fixed it...no long term damage was done, but you'd have sworn otherwise from the sound.
i will repeat that the alldata books do say otherwise on this engine, as i mentioned a few years back, but mine didn't suffer any issues, and i'm not surprized for written info to be incorrect on this engine.
now...does anyone know bout the 3.4L v6 toyota engine?? interference or no??...coming up on 70k on that baby already
1997 3.2L V6 Rodeo
Old 05-03-2008, 07:11 AM
2000izusu 2000izusu is offline
same situation. "official" sources say it is . but everybodies experience says it is a free wheeling engine (non- interference).
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
