Old 02-06-2004, 07:29 PM
Vagabond Vagabond is offline
ECM, Code 43
Recently my truck started to use excessive amount of gas, like three miles to the gallon. Repaced Knock sensor, no change. Looking for spark ESC control which the book shows a picture of it on my engine, but, my truck doesn't have one. Is it built into the distributor module? Or what can I try next?
Joe :
Old 02-06-2004, 08:03 PM
brooster brooster is offline
Re: ECM, Code 43
If you're getting three miles to the gallon and the engine runs good, you better be looking for a leak or a thief.
Old 02-06-2004, 10:30 PM
jkinney jkinney is offline
Broosters the man!
Old 02-07-2004, 11:49 PM
Cas Cas is offline
the esc module is usually on the right hand side of the motor over the valve cover gasket what is the vehicle? and year?
Old 02-08-2004, 12:43 AM
Re: ECM, Code 43
K-1500, 1993.
Old 02-10-2004, 06:57 PM
Re: ECM, Code 43
Not all trucks are equipped with ESC/Knock Sensor Module, even though the book shows it in the picture. Extremely rare for one to go bad.
I'm assuming you have either a 5.0 VIN code H or a 5.7 VIN code K. VIN code refers to the 8th digit in the serial number. The Mitchell component locater manual shows the ESC on the right (passenger) of the engine between the throttle body and valve cover for 91 and 92 models. A Knock Sensor Module is listed for 93 to 95 models with manual transmission, but no location is shown.
According to another locater I have, it lists a Knock Sensor Module for 93 if it has a 5.0 and manual transmission; or 5.7 with either trans.
When there is no module, the knock sensor feeds the information directly to the ECM and the ECM makes corrections for timing directly.
Causes of poor fuel economy include but are not limited to:
State of tune:
Worn plugs
Weak coil
Low compression
Low/high fuel press
Improper timing
Fuel system problems:
Low/high fuel pressure
Restricted fuel filter
Running rich/lean
MAP sensor problems
Defective coolant sensor
Fuel pressure regulator sticking
O2 not allowing ECM to enter closed loop
EGR bleeding by
Vacuum leaks
Fuel leaks
Coolant system problems:
Thermostat missing/stuck open
94 Geo Prizm - O/D light flashing- ECM Code 82Elky Engineering/ Technical 3 09-29-2010 07:49 AM
ECM code 26 "check engine" light dogthebear SC/SL/SW 4 06-09-2004 12:59 AM
Miss at 4000+ RPM ECM code 43 PJS2k2 Cutlass Series 4 05-29-2004 01:19 PM
95 Corolla ECM code 71 Nobodyknows Corolla/Matrix/Voltz 0 11-02-2003 12:34 PM
2001 ECM Codes DESP Malibu 4 10-26-2003 01:42 PM
