Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-05-2004, 08:18 PM
poppy13 poppy13 is offline
Ring job or replace
I have a 1990 GMC Sierra K2500 with a 5.7 Mr. Goodwrench engine. #3 cylinder is pumping oil. About a quart every 50-60 miles. I'm not a mechanic but I can only think of two reasonable options, #1 Pull head replace rings, #2 replace with a used moter. Which is the most cost effective? Or are there other options. I'm a shade tree mechanic ( very little mechanical knowledge. I've replaced starters, radiators,window motors and that's about it).
Thanks
TJ
Old 02-06-2004, 08:01 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Ring job or replace
Smartest thing is to find out where the oil is coming from.
It may be something as simple as a split valve stem seal.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 02-09-2004, 11:09 PM
herefordman herefordman is offline
Do a compression check, its an easy decision maker.
Old 02-20-2004, 12:35 AM
amac209 amac209 is offline
Send a message via MSN to amac209
a used motor would be easier. if you do put in a used replace the rear oil seal before installing it. if you do have a bad valve seal it's an easy fix. i agree with herefordman compression tells all
Old 02-17-2005, 07:37 PM
Chrismma1998 Chrismma1998 is offline
Question Compression, How Much it too little??
Just wondering if anybody has any info on how low it can go... Compression that is. I have a 95 sierra 4x4 1500 5.7 tbi. When I ran a compression check ( to figure out a loping problem) I found that all 8 are between 128-140.. The engine uses no oil and has great power. The body is super with no rust ( New England Miracle) I'm hoping to get many more years out of it.
I think that I have solved the loping problem thanks to this site. It was skipping/hesitating just off idle 1100-1500 rpms I finally just plugged the egr line and it seems to have taken care of it. After Fuel pump, filter, tps, MAP, Plugs, Wires, Cap, Rotor, Junkyard TBI..... Wish I had found this site earlier... Anybody need a Good TBI???
I guess I'll just need a new EGR unless it turns out to be the actuator, can they be checked? I tried Vacuum on the EGR with my handheld vacuum pump, it seems to take some vacuum and then bleed off slowly, I then looked at some new egr's online and one had a note next to it " can not test with vacuum" WTF? How can I be sure mine is or isn't bad??
Thanks for the help and sorry for the rambling..
CHris
Head Job/Ring Job fishonanon Metro 9 03-21-2008 11:22 PM
97 sc 2 ring job $$ = jamesmetairie SC/SL/SW 2 03-27-2005 12:12 AM
power loss, ring job???? thebigbr Other Cars 0 06-11-2004 03:17 AM
power loss, ring job???? thebigbr Acclaim 0 06-10-2004 04:23 PM
ring job on 92 Accord EX, how hard is it to do??? FastTeen Accord/TSX/Accord Hybrid 1 11-12-2003 11:21 PM
