Old 10-13-2008, 01:13 PM
Diag Diag is offline
Oil Pressure Sensor Location
Hello,
Where is the Oil Pressure Sensor located on my 2005 LeSabre?
Thanks.
Old 10-13-2008, 02:21 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Oil Pressure Sensor Location
Right side of the engine, under the power steering pump
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 10-15-2008, 01:43 PM
Thank you. Would I have better luck getting to it from the top or from underneath?
Old 10-15-2008, 02:25 PM
brcidd's Avatar
From underneath- or perhaps through wheel opening- it is right next to and above the oil filter base- like most all oil pressure sensors.
'99 GMC Yukon
Old 10-20-2008, 09:04 AM
Thanks for the help so far. I was able to locate a sensor/switch of some type on the front side of the oil pan diretly oposite from the drain plug. Is this the oil pressure sensor? I am assuming if I remove this oil will drain out. Is this true?
Thanks again.
Old 10-20-2008, 09:14 AM
C man C man is offline
I don't think that's it. That should be the oil level sensor and yes the oil will drain out.
95' PARK AVENUE 168,000 MILES
Warning : Listen at your own discretion
Old 10-20-2008, 09:24 AM
Thanks. But now, where is the oil pressure sensor? And when I find it can it be removed without oil coming out?
