Old 02-05-2004, 06:04 PM
Indyrider Indyrider is offline
Question 98 taurus windshield washer probs
My washer fluid squirts weak on the passenger side and almost not at all on the drivers side. Has anyone dealt with this problem before? Any advice would be greatly appreciated before I start pulling stuff apart!! Thanks!!
Old 02-05-2004, 11:25 PM
medicTA medicTA is offline
Re: 98 taurus windshield washer probs
If you remove the hose from the nozzle at the windshield does the washer fluid shoot out the hose with a good force?
If it does then you need to carefully clean out the nozzles without using anything steel. Use a nylon bristle off a broom for example.
If it doesn't, disconnect the hoses and blow through them to check for obstructions.
If you don't have any reasonable output from the pump with all hoses disconnected, then check the inside of the resevoir for debris, before you replace the pump.
Old 02-08-2004, 07:14 PM
Found a leak in the hose leading up to the hood. Thanks!
Old 02-08-2004, 11:31 PM
No problem!
01 Chevy Venture. Windshield Washer prob burakis123a Venture 4 08-14-2007 01:44 AM
Windshield washer probs sirsmiley Cavalier Problem Diagnosis 3 12-01-2005 11:51 AM
99 taurus windshield washer motor location hotmoney Taurus | Taurus Wagon 2 09-05-2005 04:49 PM
2000 Taurus SE windshield washer hose replacement titantn24 Taurus | Taurus Wagon 2 12-01-2004 11:53 PM
96 taurus windshield washer won't work cassiopia Taurus | Taurus Wagon 5 10-14-2004 07:37 AM
