Old 02-05-2004, 04:42 PM
violator6090 violator6090 is offline
Power
Whats a better idea for the price? Adding a Head and Cam package? or adding a supercharger to 98 T/A LS1? whats the benefits of each?
Old 02-05-2004, 07:24 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
Re: Power
I'd do the head and cam package personally. Build the motor right the first time, and then use FI if you like...
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 02-05-2004, 10:42 PM
HotBoys09's Avatar
HotBoys09 HotBoys09 is offline
Send a message via AIM to HotBoys09
Yes I would deff. agree. Even though those eights are rock solid...I would make sure the rest are able to handle the more pressure on those parts...Then at the FI, Then it would be terrifyng...
1999 Plymouth Breeze
1995 Ford Probe GT - R.I.P.
1987 Dodge Daytona Shelby Z
WTB 98+ Formula/TA or Z28
Old 02-06-2004, 01:24 AM
petereggy petereggy is offline
Re: Power
yah go with the heads and cam package because if you try and put FI on a stock motor it will not last very long. make sure your valve train and all that can handle the psi before adding FI and plus the heads/cam pack will give you around a 100hp boost if not more and once you supercharge that...watch out
Old 02-06-2004, 08:30 AM
hot_red_z28 hot_red_z28 is offline
Send a message via ICQ to hot_red_z28 Send a message via AIM to hot_red_z28
Re: Power
I don't think there is much of an aftermarket for LS1 heads as of yet is there? Maybe a company or two? I'd say you'd be better off just getting the stock ones ported out and flow tested. Then get a custom grind cam to match your flow numbers.
The right cam makes all the difference in the world and if matched up with a nice set of ported heads could easily put a stock LS1 over the 400hp mark...
My Project Write-Up
Old 02-06-2004, 05:37 PM
PowerCrazy PowerCrazy is offline
i totally agree with everything said... wait til later for the FI. you can get plenty of power from the head/cam package and that's all from engine work. get as much power out of the motor that you can FIRST before adding in other components. plus petereggy was right in that the head/cam pack will give you a huge boost... and i think it's actually upwards of 100hp closer to about 120-140hp... at least that's what it is for LT1's
Old 02-09-2004, 10:55 PM
Re: Power
alright awesome thanks alot guys...and im guessing by FI you mean supercharger right...and to hot red z 28 SLP has a pretty sweet Head and Cam package when i get the money ill hoppefully buy it...
Old 02-10-2004, 10:13 AM
Re: Power
FI means Forced Induction, i.e. a supercharger or turbocharger..
Power Locks, Power Antenna, Power Loss... keyplayah71 Park Avenue 3 10-27-2009 08:54 PM
power power power badassfocus1101 Focus | C Max 6 06-07-2005 02:42 PM
Power Power Power cacattack Sonoma | S-15 5 12-04-2004 12:41 AM
no power to power windows and power seats BlueCivic83 Cherokee 0 09-10-2004 05:49 PM
Power,Power,and More power!! Did I metion Power??? BigErbGSR Engineering/ Technical 1 04-04-2002 07:44 PM
