Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 05-30-2004, 10:11 PM
cacattack cacattack is offline
Send a message via AIM to cacattack
Power Power Power
my trucks in need of simple but beautiful... power
and im not asking oh what should i do what should i do?!?!?
ok maybe i am a little...
so i really wanna put a 350 in the sonoma (oh yeah i have a 91 sonoma)
but i wanna know... would it be worth it/ better to put the 350 in, or could i do exhaust, intake, yada yada yada to get the same results
also... tight buget, so which would be best?
Old 06-16-2004, 05:26 PM
jmc3 jmc3 is offline
Re: Power Power Power
depends on how much power that you want. bolt on's and exhaust will only give 25 to 40 hp tops. You could jsut throw a bottle of laughing gas in it too. 350 lt or ls 1 would be awsome though.
Old 07-10-2004, 09:51 PM
NWGAZQ8 NWGAZQ8 is offline
Also what motor do you currently have? It's easier to pump up a 4.3 than to go crazy w/an eng. swap, but it you want a V8 there is a manual just for S-truck V8 conversons... You can usually find an add for the book in the back pages of Hot Rod mag.
Old 09-11-2004, 08:25 PM
fuglyvortec fuglyvortec is offline
Your main concern with that engine swap is the weight factor. Your suspension is not set up for that much pressure. Also, the entire drive-train will need to be replace, as well as the rear end if you want to get all your little ponies on the ground instead of just at the flywheel. If you've got the 4.3, it's much easier to beef up this lighter engine to get more performance.
A mild cam and rocker kit, tranny, carbon drivshaft and posi-locker will definately give you a kick in the pants from that 6 pack.
If on the other hand you've got the 4-banger...I'm sorry.
One other thing, all V-8 swaps for these trucks requires the removal of A.C. system.
Old 09-29-2004, 05:36 PM
robitrice19 robitrice19 is offline
My friend has Full Flowmasters and a Full K&N intake system and it is powerfull. He can chirp them through third no prob wit just the intake and exhaust. It beats most cars in the area and has great power.
Old 12-04-2004, 12:41 AM
j.patelia j.patelia is offline
What I'd say...go 1JMz..you know the infamous 3.2L toyota made Supra engine..only seen one swap to date..thing was simply awesome...dyno'd at about 350hp..twin turbo..and was a rocket!
