Old 02-04-2004, 09:09 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Question Mustang (Model) Help
Im building up a model kit of a 1988 Mustang GT Convertable. Heres all my "scale" mods: Cold Air Intake w/ Conical Filter, 125 Shot Nitrous, New Battery Cables, New Brake Lines, New Fuel Lines, Nology Spark Plug Wires, New Ford 8.8in Rear End, Weld Drag Lites, Drag Radials, Stripped Interior, Roll Cage, Single Racing Seat, Hurst Shifter 5pt Harness and a tach .. Maybe an AFX 6" Cowl Induction Hood.. I'll be sure to show you guys first before i get over to the model car forum section. So, heres what i need help with.. As you read before- i pretty much wired up every important wire, so, now i need to know where these lines connect. I circled the areas where i dont know where they attach to. Maybe some pics!
wheres the oil dipstick go? (BTW, the brake cylender/booster is from a 95 GT)
Not sure, but that line by the throttle body looks like it connects to the oil filler spout thingy.
tEH 302 NEWB
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 02-04-2004, 09:22 PM
SIKCRX SIKCRX is offline
Re: Mustang (Model) Help
either that is a real engine, or you are getting good at those little toy cars.
Old 02-04-2004, 09:33 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i'm not too sure what you're trying to say here, i can't even see the wires you're talking about in those pics. see if you can clear stuff up for us and we might be able to help you.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 02-04-2004, 09:42 PM
for the first picture: I circled where the lines ended, or where you cant see it anymore in the picture. So, where do they go after the circleed area?
Pic 2: I see the dipstick, but where does it go down? That, and that other thing, i just wnated to know what it was, so i can try and re-make it in 1:24 scale.
Pic 3: Same as the first pic almost-diff. angle, except for the black line that goes from tb to oil filler.
Old 02-04-2004, 09:54 PM
more pics:
The white wire that i highlighted, i want to know where the white end goes
Heres a better pic of the dip stick to help describe my question
Old 02-04-2004, 09:57 PM
just a shot out of the dark but id imagine that the dipstick would eventually find its way to the OIL PAN.
Old 02-04-2004, 10:10 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: Re: Mustang (Model) Help
LoL w3rd! Yea the dipstick just goes to the oil pam. That line you highlighted I believe is an A/C line and it just goes to the Canister on the passenger side. The pic of the Red one yes that line goes form the oil filler nexk into the TB.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 02-05-2004, 08:38 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
OK lets see now.
-The dip stick goes down between the 3rd and 4th header tube (drivers side obviously) down to the oil pan.
-In the last pic with the blue lines. That's the AC low side. It runs to the AC condenser that resides in front of the radiator.
-In the first pic, that's the AC high side line. It runs to the AC evaporator, then goes in side the car though the fire wall to the AC core, kinda near the radiator core.
-OK, last one. The pic with the red engine bay. That line does go from the TB to the oil filler spout on the valve cover. It's part of the crank case ventilation for emissions.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 02-05-2004, 10:37 AM
Originally Posted by HiFlow5 0
OK lets see now.
Thanks that helps alot
Old 02-05-2004, 10:45 AM
HiFlow5 0's Avatar
Stanger
sure!
-2013 Ford Flex
-1999 Ford F150
