Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-04-2004, 06:24 PM
carpunk carpunk is offline
ignition switch
does it take 24 hours for the ecu to reset after you replace the ingition switch because it wouldn't start last night when we replaced it but this afternoon we tried 3 separate times and it fired right up
Old 02-04-2004, 10:04 PM
pegasus757 pegasus757 is offline
Re: ignition switch
should have started right away
Old 02-04-2004, 10:56 PM
NeonStyl NeonStyl is offline
Send a message via AIM to NeonStyl
Re: ignition switch
Disconnect the negative battery terminal and/or remove the fuel pump fuse from the fusebox under the hood.... wait a couple minutes & your ECU is reset.
L8R,
~NeonStyl
- www.neonspeed.com -
DIC & Ignition Wiring Diagram ugsrich Grand Prix 1 12-14-2010 07:55 PM
Not Starting, did ignition switch - no help Royalwapiti Intrigue 10 02-10-2010 01:37 PM
Ignition Switch mb8668 Eighty Eight 9 11-01-2009 08:41 AM
Anyone know anything about ignition switches? angel_iz378 Cobalt 3 09-08-2009 11:52 AM
