Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-04-2004, 04:21 PM
munchie munchie is offline
Question 1992 Maxima - low mpg, knocking during driving, idle searching
I have a 1992 Nissan Maxima SE with 140,000 miles on. Recently, engine shut itself off twice while driving but I was able to restart it. Had the engine diagnosed 4 x (twice by the dealer and twice by another mechanic) and was told that engine was running fine and that they could not duplicate fault (No fault codes either). I have had the engine cleaned as well as the Throttle Body. In addition, completed 2nd tuneup in 2 yrs. Current problem is that the car is getting about 18 mpg in the city 0 about 2.5 less than normal and that the engine seems at random times to be starving for gas. For example, will be driving down the street at 35-40 mph, 2000 rpm and the engine will drop to 800 rpm with the engine sounding as if no fuel is getting to the engine and then a second later, the car responds as if nothing has happened. It also sounds rougher than normal. Still has normal pickup, though sometimes sluggish. Additionally, getting a little knocking at various times, usually at the lower speed levels and gears. Lastly, idle at times seems to be searching for itself. Normally idles around 700-800, but is now idling anywhere from 700-1400.
Fuel used - always 91 octane or higher
Oil Change and Preventative Maintenance - always at 3000 and on time
No other major problems with engine since I owned car.
Old 02-07-2004, 09:24 PM
fugi fugi is offline
Send a message via AIM to fugi
Hi,
I had a similar problem. I think after I steamed my engine that water on the distributor cap caused the problem. After a few drives it would go away. It only happens again if It rains really bad. Also, I had a plastic water sheild missing on the bottom of my car. I replaced it with one from a yard and the problem hasn't happened again. You also might wanna try Maxima.org because I saw a post relating to this a few days ago.
Good luck,
Matt
2002 Grand Prix GT Coupe getting poor MPGs low 20s in mixed Driving mtsav8or Grand Prix 8 11-17-2008 08:30 AM
1992 Buick Lesabre periodically accelerates during low-speed braking? Pod61 LeSabre 5 01-24-2008 07:59 AM
2000 GMC Jimmy - Tries to change to 4 Low during driving ckkc Problem Diagnosis 3 12-02-2006 02:18 PM
Jeep Cherokee knocking during idle dyankee1995 Cherokee 1 10-09-2006 10:23 AM
Insufficient RPM, low power and low MPG rantruck Ranger | Courier 5 01-23-2005 12:54 AM
