Old 02-04-2004, 01:27 PM
texasz28girl texasz28girl is offline
Help guys!
I have a 1995 z 28 that's having some electrical problems. Several of the display lights come on when I turn on the headlights- like the parking brake light, ABS, hazard lights. It's weird because everything works fine- I just don't know why the display lights are coming on. Also related to this I'm sure- if I use the turn signal when the radio is on, the radio starts flashing or shuts down altogether. Now, I have a new battery and alternator- so that's not the problem.
[email protected]
Old 02-04-2004, 02:42 PM
hot_red_z28 hot_red_z28 is offline
Send a message via ICQ to hot_red_z28 Send a message via AIM to hot_red_z28
Re: Help guys!
Hmmm...regardless of them being new, usually voltage fluxuations are a sign of a bad alternator. Try starting the car up, and then disconnecting the negative battery terminal. Let the car idle for 5-10 mins with the headlights on. If it doesn't have any problems doing that, then it's not the alternator. If the lights get dim, or fluxuate, or the car starts having problems idling, I'd say it's without a doubt the alternator.
Have you hooked up any extra wiring in the car lately?
My Project Write-Up
Old 02-04-2004, 04:11 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: Help guys!
Umm it has been brought to my attention that you don't wanna do that to a computer car. The voltage spikes can kill the computer. Accually I think I might of killed my computer doing that.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 02-04-2004, 04:20 PM
cannibalrights's Avatar
cannibalrights cannibalrights is offline
Re: Help guys!
Wait untill 89IROC&RS anwersers. He'll tell you.
Old 02-04-2004, 04:21 PM
Re: Help guys!
mabey a dirty or loose connection
Old 02-04-2004, 04:22 PM
Bronco2 Bronco2 is offline
Re: Help guys!
ABSOLUTLY do not disconnect the battery with the car running-you will more than likely fry some electonics. Let me think a few minutes on this.
Old 02-04-2004, 04:34 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Help guys!
sounds like a short circuit to me...
Old 02-04-2004, 05:22 PM
Re: Help guys!
I think you will find a bad ground on your headlite / parking lite circut. Not 100% sure on your car,but these grounds usually gang together and mount to the radiator support. If you have a small lead coming off the neg. battery cable,make sure its hooked up. A quick test for this would be to disconnect one headlite-find the ground wire- temporarily attach another wire and hook it directly to batt. neg. This will give another ground circut,and if your problem goes away its just a matter of finding the wire/connection thats causing the prob. The reason your radio is involved is because the turn signal is looking for ground and feeding back thru the dimmer circut for the radio. Sorry to be so lengthy,hope this helps.
Old 02-04-2004, 05:34 PM
vettemaan's Avatar
vettemaan vettemaan is offline
Send a message via ICQ to vettemaan Send a message via AIM to vettemaan
Re: Help guys!
I hate Electronics
Old 02-04-2004, 07:17 PM
Re: Help guys!
This is not electronics,just an electrical problem. The PC you just used has chips,etc. Hate them all you want,but you could not have posted your opinion,which has nothing to do with the problem that was posted, without electronics. No offence intended,but if your going to reply,why not make it something helpful? I relize you have been on this forum much longer than I have,and I know they have off topic and stress relief forums,which is where this reply should be.
Old 02-04-2004, 07:37 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Help guys!
DO NOT DISCONECT THE BATTERY!!!!!!!
ok, ground is a good idea, however i do not feel that this is the case. what is more likley is that when the alternator was installed, somehow, somewhere, a bundle of wires were pinched and are shorting together, so when you turn on your headlights, instead of sending power just to your headlights, it energizes all the wires simoultaniously, so the lights come on. as far as the turn signal and radio being together, ill have to look into that. ill see what i can find for you tomorrow at work, see if there is any answers in the wiring schematics. it could also be a bad BCM.
lol, um, vettemaan, what do you think that vette is made of lmao
and bronco2, i understand where your coming from, but that wasnt a burning flaming or out of line post, it was kinda funny, he just had something to say, no harm in that.
speaking of off topic posts, is it just me, or is it awesome that there are finally girls logging onto the forum
back on topic, texasZ28grl, ill see about photocopying the schematics for you, and try to point you in the right direction if i find anything worth bringing up. kinda a tough problem without actually diagnosing the problem, but im pretty sure it is something to do with the BCM, and a wiring harness somewhere that all these subsytems are routed through.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 02-04-2004, 08:43 PM
Re: Help guys!
If I was to hard,I apologise. But, back to the problem-from reading Texasz28 post, I get the impression that the lite problem started earlier,and the alt. and batt. were thrown in as possible quick fixes.I could be wrong on this,but the only thing I see that ties all the probs. together is ground. As far as off topic-do you think girls get quicker replies?
Old 02-04-2004, 10:04 PM
89IROC&RS's Avatar
Re: Help guys!
lol, absolutely girls get faster replies and no prob on the reaction to the off topic stuff, sall good
Old 02-04-2004, 10:31 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Help guys!
a blower will solve all your problems
Old 02-04-2004, 11:04 PM
Vlad_Tepes's Avatar
Vlad_Tepes Vlad_Tepes is offline
Re: Help guys!
Wouldn't it be funny if it was just a dude posing as a chic?
Yeah yeah I know it looks like grandpa's but wait til I put the LT1 in it
Told my uncle I would help him with his Jetta, now I need your help guys ! 99_Mustang_GT Jetta/Vento/Bora 0 12-28-2003 08:40 PM
Need some help guys evil_elmo Asia/Pacific 55 01-06-2002 10:55 PM
Need Help Guys!!!! Pick The Best Number Plate For Me!!!!! Lambo_BoY Diablo 16 11-27-2001 06:00 PM
Help guys!!! unite@af Eclipse Problem Diagnosis 3 08-22-2001 10:25 PM
