Old 12-29-2001, 04:06 AM
datsun510dude datsun510dude is offline
Engine detail/plug wires
Im planning on doing major detail on my models or at least a couple. I was wondering what tricks or tips do people have for making the engine compartment more realistic. I know hoe to make spark plug wires (heat up the plastic tree for your model parts and strech the melted plastic out) but what else to people do?
Thanks
Josh
Old 12-29-2001, 07:09 PM
modelfan1's Avatar
modelfan1 modelfan1 is offline
Send a message via AIM to modelfan1 Send a message via Yahoo to modelfan1
it's much easier to find some wire (telephoe wire,electric motor winding wire) at Radio Shack or electric supply store than stretching plastic sprue. Different sizes can be duplicated by taking off the insulation on the wire. Pre wired distributors and distributor caps with holes already drilled are available from a couple of aftermarket suppliers.
Scale Dreams
Old age and treachery will overcome youthful exuberance everytime !!
Old 12-29-2001, 07:16 PM
Jay! Jay! is offline
Horizontally Opposed
I bought a 10 foot phone cord from the 99¢ store for (duh!) 99¢, and inside the main casing are four wires: red, yellow, green and black. There's no reason they couldn't be painted, either...
Hierarchy of Subaru:
(Click to see mine!)
Old 12-30-2001, 03:42 AM
primera man's Avatar
"P-Man"
Scale Dreams
Thanks for that site.....very good !!
View All My Models Here.
Old 01-08-2002, 11:37 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
Im getting ready to do a triple-throw-down SB2B Chevy engine in the next week or so. I plan to throw everything I've got in my arsenal at it and will be posting updates on my website. If you'd like I'll do a thread on it here.
Russ
This was my last detail hammer
My AF Classic Model Car Gallery
Old 01-09-2002, 02:33 AM
4x4 Cactus 4x4 Cactus is offline
thats one damn nice piece of work you got there. how long did it take you to do that?
Old 01-10-2002, 12:46 AM
Murco's Avatar
Maximum Car Guy
Thanks,
The carb took about 3 weeks to get right (scratchbuilt), the manifolds about 1 week of correcting, the smog system took 3 weeks, and the aluminum sheet brackets were the real monsters at 6-7 weeks of trial and error experimenting. The vavle covers were thinned and replated by Little Motor Car Co - taking 4 days on rush job, the electrical wiring was done a little at a time, the fuel lines were easily done as were the pulleys that I machined myself. The rubber v-belt took 15 minutes to make and the functional dipstick (with oil on it) took one night to get right. The other monster headache was the water pump that was scratchbuilt from layered plastic, filed and sanded to shape.
It's really hard to quantify the actual build time as it was done in free time over a year with the rest of the car.
Russ
Old 01-10-2002, 03:26 AM
Guiddy's Avatar
Guiddy Guiddy is offline
The battery terminals look brilliant!
Old 01-10-2002, 05:03 AM
"P-Man"
MY GOD......That's a bloody master peice
The carb looks just like a true 4barrel
Old 01-11-2002, 12:32 AM
Murco's Avatar
Maximum Car Guy
Thanks for the comments!
The terminals are soooo easy!!
Take some solder, drill directly into the center of the end of it just a little with a pin vise, cut it 1/8" from the end, flatten the undrilled end just SLIGHTLY, drill a small hole in the center of the flattened area, make a small slice from the cut end to the flat hole with an x-acto knife, and do the final shaping with a flat file to get the sizes right. Solder files and cuts very easily and looks darn good when done.
Old 01-11-2002, 12:35 AM
Murco's Avatar
Maximum Car Guy
I forgot!!
Sand off all molded in terminal and wire detail from your battery, get the surface perfectly flat, drill a small hole for each terminal, and use brass wire to mount the lugs. Finish the job with Humbrol "flat aluminum" to mimic the lead on the real car...
Russ
Old 01-11-2002, 01:01 AM
Murco's Avatar
Maximum Car Guy
No, just well documented and researched. My best friend, Bob Jernigan... HE built a MASTERPIECE!!
Russ
Old 01-11-2002, 01:03 AM
Murco's Avatar
Maximum Car Guy
And while he's wrapping-up the rest of that model...I'm gonna kick his butt with my next car!!!
Russ
Need Wiring info for E350 Cruise Module jdemaira Econoline 0 01-18-2011 02:16 PM
replaced my plugs and wires on my 2002 Gc sport 3.3 chevyn0va1 Caravan | Voyager 4 10-24-2010 06:38 PM
Detailing A Big Block / What Size Are The Plug Wires? NOMADGAMER Car Modeling 1 03-12-2005 04:39 PM
plug wires for detail questions aaroncrombie Car Modeling 10 07-08-2003 01:54 PM
Got wire for engine detailing modelcarmaster16 Car Modeling 5 05-19-2003 12:41 AM
