Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-01-2004, 03:26 PM
kkamakasi kkamakasi is offline
Send a message via AIM to kkamakasi
what is a header?
what is a header?
what is it for?
i'm completely oblivious to car parts and stuff...but i'm trying to get there...
Old 02-01-2004, 05:23 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
http://s94031292.onlinehome.us/images/PDRM0370.JPG
That my friend, is a header.
Old 02-01-2004, 05:53 PM
THEOLDMAN THEOLDMAN is offline
Re: what is a header?
That is a header. Since the engine is not a V block you don't need 2 headers.
Check this site out:
http://auto.howstuffworks.com/question172.htm
Old 02-01-2004, 10:52 PM
mmont0's Avatar
mmont0 mmont0 is offline
Dude, exactly right. Headers are basically the pipes that connect to your engine/cylinders for exhaust expulsion. If you have a 4 cylinder car, you have a header with 4 pipes going into one tailpipe. If you have a six inline, you usually have six going into one pipe. For a v-block, they usually split the headers into two sets - 2-3's for a 6 cyl. and 2-4's for an 8cyl. For really expensive cars they usually have each set come out of separate tailpipes. You might ask why? Well, the faster you can expell the exhaust, the more horsepower you get from your engine since it has to work less to "throw out the trash". This idea carries over to your headers as well. The larger the header, the faster the gases are released. Of course, if you have a larger header and it goes into a small tailpipe, it does you no good. You have to make sure that if you want to spend the money on a bigger header, you also should invest in a larger pipe system for the entire exhaust of the car. Eventually, this only adds about 30-50 hp to your auto. I looked under the RSX and it seems to have larger exhaust pipes than other cars I've owned. Hope this helps a little.
Old 02-02-2004, 07:16 PM
crazy_canuck crazy_canuck is offline
30-50hp? Not for the RSX. Around 5 if you get a regular header, and a race header (illegal and problem to install) you'l get 10-20whp.
Old 02-02-2004, 07:22 PM
mycivic's Avatar
mycivic mycivic is offline
They are pipes connecting the engine to exhaust like mmont0 said. You have one pipe for each cylinder. And I dont think its 30-50 hp...It would be more like 10-15, maybe 20 hp.
2003 Honda Civic LX
Mods: Bone Stock
Old 02-02-2004, 09:48 PM
SiGNAL748's Avatar
i dunno where you guys are getting your numbers from. i say around 5-7whp from a header if you're lucky, and depending on displacement.
but most people are EXTREMELY FGUKCIGN LUCKY to get more than around 20whp from i/h/e
Old 02-04-2004, 09:23 AM
Most people think that all the HP is cummulative, but it isn't. They read the thing put out by the intake, header, exhaust manufacturers and say well that adds up to a total of XX HP, and don't take into consideration that they are tested under "ideal" conditions. You have to take into account drivetrain losses, dirty pipes on exhaust systems (although SS constuction minimizes this). Have you ported and polished your heads and header to match perfectly? Is the cat-back mount absolutely perfectly lined up? etc.etc.
What headers should i get? 96Maro Camaro Discussions 7 03-01-2004 11:09 PM
what header will fit b16a? crxsirpr '88 - '91 Civic | CRX | Wagon | Shuttlee 1 10-27-2003 12:44 AM
Trying to find what headers to get Joshs2002Silverado C/K 2 10-22-2003 06:47 PM
What Header???? Civic Jim '88 - '91 Civic | CRX | Wagon | Shuttlee 10 04-25-2003 04:13 AM
88-91 Civic/CRX B16 owners: what headers? 13secondcivic '71-'87 Civic | CRX 11 01-10-2002 09:26 PM
