Old 01-31-2004, 07:53 PM
super_tuner403 super_tuner403 is offline
MY Type R SUBS
I have 2 12" type R SWR-1241D and I dun noe wat kind of amp to run them. i dunno if i should run them on a mono amp or 2 channel amp
Old 01-31-2004, 07:56 PM
Re: MY Type R SUBS
i found an amp with these specs will it run my subs and give it lots of kick or not enough RCA and Speaker Level Inputs
4 Ohms Stereo : 100 Watts x 2
2 Ohms Stereo : 200 Watts x 2
4 Ohms Mono : 400 Watts x 1
Old 02-01-2004, 02:56 AM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
Re: MY Type R SUBS
Depends if the amp is reliable. What brand and model is it?
I love them sub wufers
Old 02-02-2004, 03:40 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: MY Type R SUBS
I've heard that even feeding the Type R's the recommended 300 watts barely gets them moving. I've only seen 2 setups with Type R's in person. 1 person was running 2 Type R 1241D's with a Memphis amp running 1 ohm which gave the subs 1000 watts. And I've seen 2 Type R 1221D's with the Alpine MRD-M1000 amp wired for 2 ohms. Both systems sounded great. the one running the mrd was in a sealed box and it sounded really good. The other setup with the memphis amp was in a huge ported box and that thing really fucking hit. Can't really tell you anything about sound quality for that one because it was sitting in a stereo shop.
Empty Pockets Racing Member #1
Old 02-03-2004, 06:07 PM
i am porting my box . i've been told that the new apline mvr amps will aren't that good for my subs . he recommeded phoenix gold titanium amp would work better.
Stock Radio for installing Subs/Amp? robkule422 Car Audio 8 02-01-2011 07:29 PM
X-TYPE 04, reseting Airbag signal.. Cheffo59 X-Type 0 05-04-2010 08:14 PM
Alpine Type R 12'' Sub (What amp do I buy???) Nolte123123 Car Audio 2 11-04-2003 07:36 PM
Type R subs AKKORDINGLY SICK Car Audio 29 10-08-2003 10:54 PM
are alpine type s subs good? compared to comp vr's? AznDragon Car Audio 5 03-04-2002 05:22 PM
