Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 01-31-2004, 09:48 AM
rickfarl rickfarl is offline
zx2 rough idle vibration
has anyone had any luck in getting the rough idle /vibration at idle corrected. there was a tsb out and the dealer replaced the 3rd engine mount and elongated the belly pan bolts but its still there it is at idle and the steering wheel shakes and its just damm annoying.
the engine seems like it runs fine and it has plenty of power. when you put it in neutral it goes away and when you put it in reverse it seems to get better but drive is a killer. is this a common problem and is there anything to make it better .
the car has 8,400 miles on it and my wife is driving me nuts about this.
this is my first post and i would appriciate any help here
Old 02-19-2004, 09:07 PM
knockout_jab knockout_jab is offline
Send a message via AIM to knockout_jab
Re: zx2 rough idle vibration
The idle on my 99 zx2 was very rough. I recently upgraded the spark plug wires--a highly recommended movement for any zx2ner out there. The idle isn't completely fixed. Sure, there is a slight shake but the difference is definitly noticable. Being that your car has so few miles on it, this might not do a lot. But I know I should have done this sooner.
Old 03-10-2004, 06:27 PM
Well i found out thru just driving the car that in warmer weather the rough idle is not as bad asi think the motor mounts get a little softer and it absorbs the engine vibration there is a tsb out this problem and it involves slotting the belly pan bolt holes and installing a ner #3 motor mount bracket this involves all 2002 escorts
Old 03-12-2004, 08:18 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
I noticed from experience that zetec engines can get condensation in the spark plug housing and makes for a rough idle. Ford tecs say not to spray the top engine where the guard is , espeacially on older models.
P0171 Rough idle uspres2020 Escort 8 04-28-2010 08:06 PM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
zx2 rough idle vibration garync1 ZX2 3 03-10-2009 11:05 AM
Rough idle, vibration, shimmy @ 50-65 mph on a 94 pjlipeika Blazer 6 04-15-2005 03:46 PM
