Old 01-03-2004, 09:52 PM
pjlipeika pjlipeika is offline
Rough idle, vibration, shimmy @ 50-65 mph on a 94
When traveling at high speeds, my 94 blazer idles rough, vibrates, or shimmys. I don't know what is causing it. The computer is clear. Just replaced the egr valve, spark plugs, and fuel filter, and it still does it. The wheel bearings were checked and nothing appeared to be wrong with them. I jacked it up all four wheels off the ground and brought it up to high speeds. No vibration from any speed. There is no vibration at any speed below 50 when traveling on the road. When it starts to vibrate, i will throw it into neutral and the vibration will cease for the most part. Any helpful hints or advise on what to check would be exremely helpful. Thanks in advance!
Old 01-04-2004, 05:30 PM
N2planes N2planes is offline
Re: Rough idle, vibration, shimmy @ 50-65 mph on a 94
Check the tires if they are worn, say a year of driving. Chances are that is the problem. That is when I know it is time to replace mine when I get vibration.
Old 01-04-2004, 06:34 PM
Nope, they are brand new tires. They still have the blue on the letters. This is really starting to get me upset, not mad, but upset.
Old 01-08-2004, 11:36 AM
vinnie97 vinnie97 is offline
could be your driveshaft not balanced or a u-joint amongst other things
Old 01-15-2004, 06:35 PM
kpobrien kpobrien is offline
Send a message via AIM to kpobrien Send a message via Yahoo to kpobrien
Thumbs up Re: Rough idle, vibration, shimmy @ 50-65 mph on a 94
try cheking the fuel injection unit (or the cpi as it is also know as )mechanism under the plenum it seems to go bad frequently and cause all the simptoms you have discribed email me if you need further information @ [email protected]
DARKNESS IS GREAT
Old 04-15-2005, 09:10 AM
chris22888 chris22888 is offline
Iam haveing this exact same probleam on my 95 jimmy. Did you ever figure out what was causeing your probleam. If so let me know please.
Old 04-15-2005, 03:46 PM
herkyhawki herkyhawki is offline
Listen to Vinnie.
It's a bad U-joint on the driveshaft.
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
Front end shimmies past 65 MPH spinner074 Celebrity 3 10-09-2007 02:45 PM
Shimmy at 65 mph sabsaw Suburban 10 04-03-2007 12:17 PM
Vibrations at 57-65 mph! hmoritz C/K 4 11-19-2003 02:18 PM
