Old 01-31-2004, 04:35 AM
pAint pAint is offline
Send a message via AIM to pAint
94 grand am ABS light
I can't seem to figure out why my ABS light doesn't turn off on my 94 grand am SE. I change the pads, rotors, and fluid... and still nothing. Can someone help?
Old 01-31-2004, 12:25 PM
justin0419 justin0419 is offline
When you get a light on your dash, don't just start randomly replacing things. Get the code checked out to see why the light came on. There are many different things in the ABS system that could cause the light to illuminate. Your '94 should be prior to the OBDII ECM, so you should be able to get the trouble code yourself by grounding out two of the posts on your engine diagnostic plug. If you need to know how to do this, let me know.
Old 02-01-2004, 02:13 AM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
Re: 94 grand am ABS light
That will only work for ECM codes the abs codes will have to be retrieved with a scan tool.
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 02-01-2004, 05:30 PM
I didn't just start buying parts at random, i needed them. One of my rotors were cracked, so i got those replaced. Then pads were low too, so i did everything at once. I heard you can disconnect the batter to reset the puter. Pls lemme know... thx
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
'95 Town car ABS light on and hesitation olopezm Town Car 5 12-02-2010 06:30 PM
95 silverado abs light is on and smells like brakes joseriverasg Silverado 2 12-21-2009 10:15 AM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
2000 Grand ABS Light and Break light are on. thealy Grand Cherokee | Grand Cherokee SRT8 7 01-16-2005 11:20 AM
