Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 01-31-2004, 03:38 AM
vinceau911 vinceau911 is offline
Skyline Factory Turbos Max HP???
Does anybody know how much hp a pair of factory turbos from R32/R33 can produce? At how many psi/bar does these turbos max out? I have a pair of turbos with .48 A/R on the turbine housing and .42 A/R on the compressor.
Old 01-31-2004, 12:58 PM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
Re: Skyline Factory Turbos Max HP???
I am assuming you mean GTR turbo and not the turbo off the GTS-t, GTS4 (R32), or GTS25t(R33).
The GTR turbos factory have a .46 A/R on the turbine housing. I'm not totally sure on the compessor side.
They are rated to 220hp and max boost will be around 1.5kg (21.335psi). That is what mine when to when I had boost control line rupture. Thankfully they didnt' snap though I did damage the seals slightly.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 01-31-2004, 09:47 PM
Re: Re: Skyline Factory Turbos Max HP???
I guess 500-550 hp on stock turbos is not possible?
Old 02-01-2004, 02:47 AM
RazorGTR's Avatar
Skyline Man
with NOS sure. Turbos alone, no. You can only make what they can flow and produce.
Old 02-06-2004, 11:02 PM
xToRQuEx xToRQuEx is offline
Send a message via AIM to xToRQuEx
to get my 402WHP i pushed the stocks to 1.3Bar.
1993 Skyline GTR32 VSpec-Gunmetal Grey-Black Nismo LM GT4 Limited Edition 18's(200 sets made) 402WHP@6500rpm 347ft/lbs Torque@4400. Thanks to RBM
1990 240SX Custom Paint and Chromes, nothin great(in bad condition at the moment) Considering SRSwap...
Old 02-06-2004, 11:24 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
1.3, that is on the edge.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 02-06-2004, 11:36 PM
yea tested at 1.1 1.2 and 1.3 with no signs of any problems to come. its only like that for when i need that extra power. i have power fc with l-detro and commander, boost system too so i can adjust that with ease.
Old 02-07-2004, 03:29 AM
GTES-t's Avatar
GTES-t GTES-t is offline
Here's a good link that lists most of the Nissan turbos and has their approx. max pressure output and power added from that turbo.
members.iinet.net/~sayers/biscuits/turbos.htm
1990 Skyline GTE/S-t 4 Door Updated 6 Mar
Swapped out RB20E with RB20DET
Trans converted from Auto to 5-Speed...
Now with SR20DET 5-Speed
Installed Type M 5-lugs and brakes, R32 GTR rims and 2-Dr rear end (Tail lights & bumper)
1994 Isuzu AMU
US Spec Amigo with JDM Isuzu MU (Mysterious Utility, as it's called in Japan) nurf bars and hatchback style hardtop.
Old 02-07-2004, 07:53 PM
by the way, i have other modifications obviously, didnt want u to think thats all i did, so its not making all that extra power, just helpin.
Old 02-08-2004, 12:03 PM
Daidae's Avatar
Daidae Daidae is offline
Send a message via AIM to Daidae
I just got a R32, and starting plan for mods....but...
I thought it was not a good idea to boost more than 1.1 on stock R32/R33 ceramic turbos? Am I wrong? So when does the turbo start losing efficiency and blow heat?
Old 02-08-2004, 12:12 PM
originally I thought the same thing. But when they stuck the car on the dyno, they tested it, as i said, at different levels, and it never showed any signs of troubles, what so ever. but im also not planning to run them at that level constantly.
Since i do have Power FC with the boost control kit, L-Detro and Commander, its easy to change the setup for the car from different levels of power and how i want things to run. that was quite an expensive piece of equipment, but its nice. check it out, apexi makes it, but if you want it plan on something like 1800USD, thats with everything. You can get it right over 1000 without LDetro, commander and the boost kit.
of coarse there are cheaper alternatives, but i got this for other reasons as well.
1.3, and the mods i have, pushed me to 402WHP@6500 and 347ft/lbs of torque@4400.
they saw no signs of heat output or breakdown, or else they would have never suggested that it be put that high. They told me, the breaking and really risky point for those turbos are 1.4 bar.
if you would like to talk to them personally, i have numbers and AIM screen names you can contact them by. just let me know i know they wouldnt mind helping.
Old 02-08-2004, 12:46 PM
Daidae's Avatar
Cool thanks man!
Old 02-08-2004, 06:36 PM
R33's Avatar
R33 R33 is offline
Send a message via Yahoo to R33
I have run (including countless tract visit) my 33 at 1.12 bar with the car churning out 375rwhp without any problem before. But a friend of mine fried his turbo on his 34 running it 1.3-1.4 bar one night. When the turbo was opened up, guess what, there was no impellers anymore!
Hey, what are you doing in the fast lane?
Old 02-08-2004, 11:28 PM
SkylineUSA's Avatar
Yep, it will run at 1.3, but for how long until the car poops out the exhaust wheel
Old 02-09-2004, 01:33 AM
RazorGTR's Avatar
Skyline Man
Wholy bat shit, a Magazine who's figures are actually close!!!!!!!! mark it on the bloody wall. Ok done with my sarcy lol.
Seriously though they give them around 150kw or 200hp. That is the closest I've seen. I've seen factory GTR turbos rated to as high as 250hp! Ummm yea righto.
the exhaust housings on every R32 turbo I've seen say .46 A/R. Now contrary some supposedly have .48 A/R. In all honesty the difference is sweet F' all in actual power output. It would equate to less than 10hp. Before someone comes on here and spouts about N1 turbos, those where put on excatly 100 GTR's produced in 1989. These however are NOT the Group A N1's just slight bigger housings and wheels. I believe they were .64 A/R but not confuse them with the Group A N1's which had the same A/R ratings but bigger wheels thus able to produce more. They were also steel wheeled and shafts and still ball bearing. They are as rare as rocking horse shit.
Now also before someone goes off their nut claiming this about ecu's, injectors, bla bla bla. You can only force so much air through a given space. The compressor can only move so much air totally. Different dyno's will give out different readings. Some are more generous than others but also you take off less for driveline losses in which case the actual power produces is the same overall.
800+ hp BMW E30 turbo - 650+ hp Audi S2 BTT Car Videos 4 10-25-2005 02:11 PM
Max Hp Chevy2xtreme S-10 0 08-21-2003 03:49 AM
Max Hp on 68 Stang 68 Stang Mustang Talk 3 10-20-2002 08:50 AM
Max hp for 1.8 SkylineNoDoubt Integra 0 09-24-2002 12:09 PM
Max Hp subz Engine 33 10-08-2001 12:53 PM
