Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 01-30-2004, 11:07 PM
gfharris729 gfharris729 is offline
Post surging/hunting 91 626 mazda in Drive...ok in rvrs
91 mazda 626 w/ auto trans...
Engine Surges/hunts when placed in Drive or any forward gear....
Will cut off if throttle is not floored.....
Runs Normally in reverse or when in neutral....
Suspect something akin to a vacuum leak relating to what used to be called a "modulator valve"... Find nothing in my "Chilton" manual..
Help!
Old 01-30-2004, 11:09 PM
Re: surging/hunting 91 626 mazda in Drive...ok in rvrs
Any helps or suggestions will be appreciated...
P.S. I replaced the "Throttle position sensor potentiometer" as a precaution; no help.
Old 02-04-2004, 12:47 PM
rnatyte rnatyte is offline
I dont know how well you know mazdas, but a very big problem they have is the connecting hose from the mass air flow sensor to the intake. if the hose has a crack in it and you take off the crack will open and mess the air flow up. The way it act in reverse and park tells me the motor runs fine. take the hose off and bend it in all direction to check for cracks. I hope this will help you
... how is the trans.?
mazda 626 cooling fan and ac problem eliphino General Discussion 2 06-10-2012 05:25 PM
02 626 random misfire wopsmickey 626/Capella/Capella Wagon 4 03-22-2010 05:25 AM
2000 4cy 626 Mazda Transmission stuck stratagen14 626/Capella/Capella Wagon 1 11-11-2009 09:00 PM
'93 626 mazda owners manual help tommaz626 626/Capella/Capella Wagon 0 01-24-2004 11:32 PM
