Go Back   Automotive Forums Car Chat > Dodge > Viper | Viper SRT19 Roadster
Old 01-30-2004, 09:29 PM
dbone1200 dbone1200 is offline
viper rear axle loosing pinion pre-load
what would cause a brand new built rear viper axle to loose pinion pre-load. specs are from 25-35. when built will have around 29.2 after tested in the car preload will drop off and end up having a preload around 1-5. you can spin the yoke easily with your hand. don't make sence. spacer is colapsing correctly under torque.
Old 04-10-2004, 10:43 PM
Viper 10 Viper 10 is offline
Re: viper rear axle loosing pinion pre-load
You are asking the wrong forum for this kind of technical info. Most of the VCA guys couldn't answer your question.
I would contact Erik Messley or John Archer with your question.
"We will always remember. We will always be proud. We will always be prepared, so we may always be free."- Ronald Reagan at the D-Day Anniversary
Oil capacity of GTS rear axle 2006GTS GTRA / GTWS / GTS 2 10-01-2010 07:46 PM
How hard is a rear differential pinion seal to replace? mkenyon2 Modifications/How To 3 03-16-2010 10:58 AM
1999 can I swap a 2wd rear axle in the place of a 4wd rear axle? azwelding Silverado 2 04-25-2006 02:16 PM
Replacing rear axle pinion seal ? scholzee Blazer 0 11-07-2005 09:30 AM
98 Rear Axle/Pinion Gear Question skotmxpx Explorer | Explorer Sport Trac 1 01-07-2005 09:19 PM
