Old 01-30-2004, 08:50 PM
frozen_Joth frozen_Joth is offline
Easily Distracted
Send a message via AIM to frozen_Joth
Unhappy Timing Replacement
A couple shops told me around $400.00 to replace my timing belt! Is it really that hard? I talked to guy and he said I can break loose a motor mount and jack one side of the engine up and replace it myself real easy. Is it really possible to easily do it yourself that way? Any tips or info is appreciated. thanks. Oh and if anyone has a d16z6 for sale lemme' know!
'92 blue Civic Si
-B17a
-Carbon fiber intake, full exhaust
-Short throw, lowered
Old 01-31-2004, 12:24 AM
BullShifter's Avatar
Re: Timing Replacement
It's not hard and it's not easy. IMO breaking loose the crank nut is the hardest part about the job.
4 words - Replace the water pump!!!!!!!!!!!!!
http://www.binghamtonlife.com/manual...alve_train.htm - t/belt replacement
http://www.binghamtonlife.com/manual/2gsm/cooling.htm - water pump
Old 01-31-2004, 12:43 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Re: Re: Timing Replacement
That crank nut is a filthy bitch.
Honda Enthusiast
Old 01-31-2004, 08:38 AM
Easily Distracted
So I can break loose a motor mount and jack up one side of it? I'm probaly getting a dohc zc or a d16z6, something cheap. Should I just say f*ck it until I get a new engine, or is this something a novice can do?
'92 blue Civic Si
-B17a
Old 01-31-2004, 09:35 AM
kris's Avatar
kris kris is offline
Off playing with fire.
If you are saving for a new motor, why replace a t belt on the one you have now? Unless your new motor is years away.
Old 01-31-2004, 11:03 AM
Easily Distracted
I'll be getting a new motor as soon as I can find one. I can wait a week or two for this! thanks.
'92 blue Civic Si
-B17a
Old 01-31-2004, 11:20 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i agree with that. don't replace anything on the motor you're running. if anything, do all this stuff to the new engine before it drops in. we generally replace t-belt, water pump, and sometimes thermo.
another thing you might want to consider when you pull out your engine is to address things on the tranny side. since everything is cracked open it's the perfect time to replace clutch, throw-out bearing, and resurface flywheel.
thought i would throw that out there incase you haven't considered it yet. this way you can budget it into your swap ahead of time should you choose to replace those things
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
3rd time replacing the Blower Motor Relay waterkeeper03 Impala | Impala SS 7 11-27-2010 12:41 PM
99 Villager Timing belt replacement celica92gt Villager 2 08-22-2010 11:32 PM
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
Having a very hard time replacing the EVO sensor - need suggestions! pnut333 C/K 1 03-13-2009 08:30 PM
second time replacing starter luckieleo LS | MKZ 3 12-20-2004 10:54 PM
