Old 01-30-2004, 08:49 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
amp from oem head unit
How do you go about running am amp off of a factory head unit for the RCA's and remote wires? thanks
Old 01-30-2004, 11:37 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: amp from oem head unit
you want a line output convertor, turns the high level speaker signal into a low level rca signal that you send to the amps. As for the remote output, if your headunit doesn't have one you can always just connect to the switched ignition power. Your amp won't turn on and off with the headunit, but it'll turn off with the car.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 01-31-2004, 09:50 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
most of the better line output converters (LOCs) have a wire for amp turn on built in to them
Head unit install = broken speedometer? robkule422 Car Audio 2 01-03-2011 04:29 AM
Need OEM CD Player Head Unit KhunRon 3 Series 0 06-23-2007 08:15 PM
'88 Civic hatch...speaker/head unit swap w/newer honda OEM parts? annointed '88 - '91 Civic | CRX | Wagon | Shuttlee 4 11-27-2004 06:21 PM
'88 Civic hatch...speaker/head unit swap w/newer honda OEM parts? annointed Interior | Audio | Security 0 11-25-2004 08:14 PM
Any experience swapping out OEM head-units on new GMs? St0rmD Car Audio 5 02-19-2004 05:44 AM
