Old 01-29-2004, 10:51 PM
interfire83 interfire83 is offline
Send a message via ICQ to interfire83 Send a message via AIM to interfire83
Water leaking to passenger side floor!!!!!!!!!!!!
I've heard of this happening on grand prixs before but does anyone know exactly where it is coming in?
Old 01-29-2004, 11:16 PM
titleist312 titleist312 is offline
Re: Water leaking to passenger side floor!!!!!!!!!!!!
1st place or thing to check would be the heater core .
Old 01-30-2004, 01:04 AM
JOEROC JOEROC is offline
Send a message via AIM to JOEROC Send a message via Yahoo to JOEROC
first dig out your tool and bandaids or your wallet
heatercore .....sorry
Old 01-30-2004, 01:15 PM
gtgp97 gtgp97 is offline
Send a message via AIM to gtgp97
Smile
I had this problem during very hard rains only while driving the car but it was not a problem with the heater core. The problem was actually the fresh air vent from the outside in front of the passenger side of the windshield. I removed the black plastic cover and a small gutter to divert windshield water to a drain had fallen off and the plastic cover to allow water to drain off without going into the vent had come loose. I installed the a filter that comes in the regal into mine and glued the gutter in place and reset the plastic piece. Havent had a problem since.
Old 01-30-2004, 04:06 PM
carnutcass's Avatar
carnutcass carnutcass is offline
Not trying to sound like a "Know-it-all" but this is a really common problem with our cars. The drain for our AC is fairly small. Condensation drains through a small hose on the firewall. The hose clogs with crap, mold, mildew, whatever. The condensation backs up and drains on the passenger side carpet.
I'd try unclogging the drain before I started worrying about the heater core. If the heater core were bad you'd be smelling anti-freeze inside the car and your windshield would fog up when you use the heater.
I'll see if I can dig up a diagram for the drain location.
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
This is a common problem w/ the drain tubes cloging or like gtgp97 said dislodging.
Old 02-18-2004, 09:36 PM
Avion Grease Monke Avion Grease Monke is offline
I just repaired this problem on my 98 GTP. Assuming you don't smell Coolant or have fogging. Then the problem is likely a small rubber dam that is located under the exterior plastic. This dam diverts water away from the fan intake and comes loose. Remove the wipers, plastic grill beneath them and you'll see it laying there. I recrimped mine and glued it on with silicon. Good luck
97 Camry water leak passenger side OLD JOE Camry/Camry Hybrid/Vista 10 07-01-2015 09:46 PM
X3 Water Leak Passenger Side walovej X3 13 09-08-2014 10:31 PM
Water leaks into my passenger side floor board ap0c8 Grand Cherokee | Grand Cherokee SRT8 2 06-17-2009 05:06 PM
Water on Passenger side Floor jar92380 Grand AM 2 01-11-2008 07:37 PM
water leak passenger side '00 venture enelrad Venture 8 05-02-2006 06:35 PM
