Old 01-11-2008, 12:00 PM
jar92380 jar92380 is offline
Water on Passenger side Floor
Hello
I have this weird issue, I seem to be getting water in my passenger side floor. It seems to generally only happen after snow/rain. When I get into my car, my right speaker and lower right hand side of the door is just wet, could there be a problem with the seals on the door?
Thanks
James
Old 01-11-2008, 05:14 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Water on Passenger side Floor
Most likely either the weather striping or the black thing that the window seals against on the outside. If either is missing/damaged, replace it.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-11-2008, 06:37 PM
J-Ri
Thank you for your reply, how would I go about replacing the seal that is on the window to the outside? Please help explain to someone that knows almost nothing about working on a car
