Old 01-29-2004, 01:23 PM
Carnivore's Avatar
Carnivore Carnivore is offline
Send a message via AIM to Carnivore
She Don't wanna turn over,stuck at school, help!
early this morning my car started right up and ran fine, so i park at school and about 5 hours later i go in the hatch to leave and shes not turning over, shes cranks and wants to start but she jus ain't, im thinking spark plugs or Dizzy?....im sure some one has had this problem before and would like some help here, thanks
I love my honda...I hate my honda
Old 01-29-2004, 01:47 PM
Carnivore's Avatar
bump, i also have a full tank of gas and can hear the fuel pump turn on, but still no turning over, only cranking.
Old 01-29-2004, 01:50 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: She Don't wanna turn over,stuck at school, help!
for some reason i figured that this was in this forum
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 01-29-2004, 03:41 PM
dagoEF's Avatar
dagoEF dagoEF is offline
Check ignition coil and ignitor module. I had a similar problem and one of the connetors on the module were really off and the others were loose. I tightened them up and she started right up...both parts are under the distrib cap
Old 01-29-2004, 08:11 PM
Carnivore's Avatar
well i jus got it towed(thanks AAA) to the garage right down the road from me, and put brand new plugs in and still no starting right, so hopefully ill find out the real problem tomorrow, and im such a goon and never checked the ECU for any codes
Old 02-20-2004, 03:57 PM
camelhooves camelhooves is offline
I'm having the same problem, new cap, roter, plugs, and have spark. When I changed the plugs cyl 4 was realy fowled with gas but the other 3 were dry, I'm a lot confused and could use some direction as to how to proced. I'm also getting error code 15, if that helps.
Old 02-20-2004, 04:03 PM
blade34609's Avatar
blade34609 blade34609 is offline
Main Relay
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 02-20-2004, 10:26 PM
Good Times, I'll check it tomorrow.
HELP! Very aggravating problem... easy fix? krasomil General Discussion 3 03-01-2009 01:13 AM
Clunking on turns, over rough roads...Help! Hhighland Lassie Grand AM 2 03-17-2006 05:32 PM
Camaro I-roc z-28 350 V8 wont turn over wont start HELP an_Okie_here Camaro Discussions 1 05-20-2005 08:53 AM
Sometimes she smokes, sometimes she don't? CR50HC '88 - '91 Civic | CRX | Wagon | Shuttlee 17 12-26-2003 08:40 PM
Please Help, I don't wanna walk Sman Engineering/ Technical 3 09-27-2003 10:59 AM
