Old 05-19-2005, 06:27 PM
an_Okie_here an_Okie_here is offline
Send a message via Yahoo to an_Okie_here
Question Camaro I-roc z-28 350 V8 wont turn over wont start HELP
Ok I have a big problem here, my car wont turn over, wont start of course. I have replaced the starter and solenoid, neutral safety switch, ignition switch, and I have checked the battery its hot, I have checked all the fuses, and in line fusible wires. I have managed to cross over the solenoid and it will turn over at that point and will briefly run as long as the starter is still running once I remove the wire I used to cross the solenoid it dies. I do still have power to the rest of the vehicle. I am at my wits end and all out of ideas here, a little help please.
Thanks in advance
Old 05-20-2005, 08:53 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Camaro I-roc z-28 350 V8 wont turn over wont start HELP
sounds like you have a break in the wire from the ignition switch to the s terminal on the solenoid. with the key rolled over to 'run' make sure you have battery voltage on the wire..
