Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-29-2004, 01:15 PM
_~Hapex~_ _~Hapex~_ is offline
what problems come with Ls V-tech
i have the option to buy a ls V-tech engine or a 93 prelude engine which one is more of a problem for my civic plz help
Old 02-03-2004, 04:35 PM
SP_Mark SP_Mark is offline
Re: what problems come with Ls V-tech
Depending on which year and model civic you own, the prelude will be more of a problem. You need to buy custom aftermarket engine mounts and axles. You also need to do a little modifications for the shift linkage as well. The LS-Vtec motor should be pretty much an easy swap. All you need are b-series axles and you can use factory honda engine mounts. Wiring, depending on which model civic you have again will require you to wire up Vtec. If you need anything else, drop me an e-mail.
[email protected]
Just bought a 2002 Caravan with a computer problem! Experienced Dodge Computer tech wanted! mikefaster Caravan | Voyager 20 12-01-2015 04:00 PM
what muffler comes with the borla catback? Vipey1337 Grand AM 28 12-31-2006 12:42 PM
What injectors come with a 95 Eclipse RS? wickedboost Off-Topic 5 12-29-2004 01:27 PM
what problems come with Ls V-tech _~Hapex~_ Engineering/ Technical 6 02-01-2004 03:23 PM
What Equipment Comes With The Skylines? hammyox85 General Discussion 1 06-28-2002 02:58 PM
