Old 01-29-2004, 08:44 AM
John W John W is offline
Headlight Wiring Question
After an accident that destroyed the block that plugs into the headlamp on my S-10,I'm trying to rig up a new lamp and direct wire with the tabs that went into the block.Any tips on getting the right tab on the right headlamp prong?It obviously matters as I hooked it up once,had lights but lost both headlamps after driving a while with the smell of electrical problems in the cab.Thanks!
Old 01-29-2004, 12:08 PM
jcas1411 jcas1411 is offline
Painless has a great harness an plug for this. I just got done with a complete harness but I remember seeing just the light set. What year and I can send you the color codes when I get home this evening.
Old 01-29-2004, 01:21 PM
Re: Headlight Wiring Question
1993,Thanks!
Old 02-10-2004, 02:28 AM
Sorry it took so long...here is what I have with my painless kit..
facing the rear of the plug to you (you looking at the rear of the plug) the right prong is ground, bottom plug is tan wire (low beam), left prong is Light green (high beam).
I hope this helps.
Also sent private message.
2003 Venture Headlight Switch Wiring Diagram kapinossa Venture 0 09-19-2009 11:25 PM
projector headlights apple_jax_86 Pick-Up 4 08-13-2009 02:27 PM
headlights/foglights wiring question AutostradaVR4 3000GT/Stealth 10 04-04-2007 02:26 PM
Question On headlight wire harness swap Rick1488 Blazer 1 09-22-2005 03:59 AM
Wires/wiring question for audio SilverY2KCivic Car Audio 7 01-14-2004 02:26 PM
