Old 01-28-2004, 02:31 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Project Idea
With the sale of my current Mustang almost immenent I have been thinking what I what to do as my next project. I have been toying with this one idea and I'm posting it up here for you my peers to tell me if you think it would be a cool idea.
My idea is based on the arguement of wether or a not a stock 5.0 Stang can run 13's 1/4 mile. I know I have seen it said in MM&FF, 5.0 etc.., But I have never seen this nor do I think anyone else has either. My belief is this can be done but by the time I had my license the newest Fox-stang was already 5 years old and had many miles on the motor.
So my plan is to buy a 87 or 88 5.0 cause of SD(5-speed preferably). Pull the motor out and do nothing more than blueprint and balance it. Make sure everything is running perfect and tip-top. And try to assualt 13 seconds through nothing more than timing, tire pressure, and simple wieght reduction tricks like said in the magazines.
I would with the help of HiFlow like to carefully document this process step by step and put it on on AF. I think it would be cool for all you Mustang lovers here to see and if we can accomplish it it will shut a lot of people up who talk trash about the 5.0 and it would be more than just magazine talk.
I think this project has room to grow if the eventual goal of 13's is reached. Also I think it is more challenging than just going fast with a 5.0 these days which basically equates to how deep are your pockets. That's all let me know what you guys all think negative or positive opinion are all welcome.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 01-28-2004, 03:42 AM
SIKCRX SIKCRX is offline
Re: Project Idea
sounds like a damn good idea, but my n00bness is killing me....what exactly does blueprint and balance mean, ive heard these terms before but i never really knew what they meant. could you explain this to me?
Old 01-28-2004, 05:49 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Project Idea
Sounds like a plan to me! Let me know where I can help, and I'll be there. I think this is a very good idea, it would be a great idea for an "AF project car" of sorts. I too believe it is possible when set up right for a stock motored 5.0 to hit 13's. Now I do have one question for you? When you say stock, I know you'll B&B the motor, but what about port work, and the possibility of P heads and intake? Would you consider that to be stock too? I know some racing classes allow certain things like that, but would that be too much in achieving your goal?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 01-28-2004, 03:11 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Blueprint and balance means weighing everything in the rotating assembly inside of the engine to ensure that the there is no out of balance parts. Any weight that is out of balance, be it the rod, crank, piston, etc it will rob HP.
GTStang,
MY first thought was why? And thats a big waste of time? And I thought GTStang was smart, boy was I wrong
The more I think about it, the more I like the idea. Its a true way to measure ones capabilities. If you are going for a true stock, you have have to mean true stock. Not, well you can get this part, or that part from Ford, so when I install it, its still stock. That is a cop out, of sorts. Stock is stock.
I really do like the idea. I could not do it. My hat is off to you.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 01-28-2004, 04:26 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Project Idea
that is a sick ass idea i'm so for it i bet you can do it.
Old 01-28-2004, 04:40 PM
rerun rerun is offline
sounds like fun. i'lll be backing you 100% just wish i could be of service. do you know what year you will be looking in getting?
And i think skyline is right. Stock is Stock. if you are changing the timing or anything like that, it isn't stock anymore. it may not be put money into it, but that doesn't mean its stock.
Old 01-28-2004, 04:57 PM
GTStang's Avatar
Stang Guy
Well so far I think you guys get my vision and reasoning for the project. Like I said making a 5.0 Mustang go fast these days is merely a matter of deep pockets. I kind of like this idea cause it challenges me in a lot of different ways.
As far as what is stock and what is not stock. My vision is to build a motor and car which would be exactly as if you drove it off a Ford dealership back in 87-88 and went striaght to the dragstrip. So I will get 8 stock pistons spec'ed out and re-ring em, stock rods, stock crank, stock E7 heads just making sure they good but no P&P, no 3/5 angle valve job, no milling, just checked out and restored to specs. I think you all get the idea.
Run the car like that and them from thier play with timing, tire pressure, wieght reduction. But all within reason of what some1 normally does with a new car when they head to the strip to get lil ET drops.
Old 01-28-2004, 07:48 PM
Re: Project Idea
what kind of tires are you gonna be running? slicks? DR's?
Old 01-28-2004, 08:15 PM
GTStang's Avatar
Stang Guy
Well I'm gonna start with street tires but will prob use dr and slicks at some point too.
Old 01-28-2004, 08:17 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i think you should definitely get a notchback. i have a feeling that you're gonna need every pound you can get, and one of them will give you 2-3 hundred pounds right off the bat. i assume that you will be doing the 10 minute tune up (seats, etc). this is sweet, hope it all works out.
oh yeah... my buddy knows a local guy who's selling an 86 notchback like mine with some racing mods (easily removed), $600. lemme know =)
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 01-28-2004, 09:57 PM
eillob's Avatar
eillob eillob is offline
What about Gears. Are you adding them and if not, are you going to check if they have been added prior to you aquiring the car?
Old 01-28-2004, 11:23 PM
i see what you are doing. It sounds cool, experimenting is cool (get your minds out of the gutter..)
Go for it and see what happens. whats the factory claimed 1/4mile?
Old 01-29-2004, 01:42 AM
GTStang's Avatar
Stang Guy
The notchback/LX/ GT question has been on my mind. I'm going to get the best car/deal combination for what I'm looking for. Most preferable would be a 5-speed notchback. I do not want to have to do a 4cyl V-8 swap so if it ends up being a GT so be it. Yes I know I'm pulling the motor but think of all the other work involved to make it exactly like a V8 equipped stang. I want to try to simulate a showroom new 5.0 stang as much as possible but that would be too much work.
Also if the test car is a 5-speed I will be installing 3.08's if it's an auto 3.27 will be checked for and installed if needed. This isn't a big deal cause the Trac-Loc was going to be pulled and rebuilt to ensure a new like status. And yes the 10 minute tune-up will be done in stages.
Old 01-29-2004, 08:35 AM
HiFlow5 0's Avatar
Stanger
Re: Project Idea
Thinking of the notchback huh? I thought you hated the way they looked?
-2013 Ford Flex
-1999 Ford F150
Old 01-29-2004, 08:57 AM
GTStang's Avatar
Stang Guy
Re: Re: Project Idea
I do hate the way they look... but it does give me the best chance to achieve my goal of 13's. This is very important to me cause next time anyone on here gets into an arguement about it wether it can be done or it's just Ford BS can always send some1 to AF for proof, if I can accomplish it.
Also I don't see many 5.0/ 5-speed/ Notches for sale so I may be doing it in a hatch either way. I've started my search as of yesterday. My baby is gone after this weekend. Hopefully the roads are clear enough I can rip it up one more day before it goes to it's new home.
Project Ideas For Drivetrain 68coupe390 Performance 2 10-11-2010 01:08 PM
LS?VTEC project idea Pyros 97GS Engineering/ Technical 2 12-09-2003 04:49 PM
My new sleeper project idea. Polygon Street Racing 28 05-30-2003 03:26 AM
My sleeper project idea. Polygon Street Racing 18 11-26-2002 03:06 PM
Project ideas Integra06 Car Modeling 2 09-22-2002 04:01 AM
