Old 01-28-2004, 12:05 AM
99suburban2wd1500 99suburban2wd1500 is offline
Question align or aim headlights 99 suburban
Having trouble adjusting the alignment on 99 Suburban headlights, do these have any adjustment to them or are these fixed?
Thanks for posting on disabling the DRL by pulling fuse #15, too easy .
To share: finally got around to changing the rotor (@130M miles) not as bad as expected , glad to share a few tips if anyone needs to do it too.
Old 01-28-2004, 07:26 PM
777stickman 777stickman is offline
Howdy: My sub is a '99 carryover, which means it's the old body style. So, yes there are adjustment screws for the headlamps. They are hidden in holes in the support bar in front of the radiator and are deep down. Use a flashlight to find them. They have an outside socket or an inside torx. Can't remember which does which or which does up, down, left or right, but you'll figure it out, I'm sure..........Steve
Old 01-29-2004, 12:22 PM
Re: align or aim headlights 99 suburban
Yes, I saw those hidden knobs, and I dont' remember which ones I turned nor which way, but fore sure I turned them all, all ways, and did not see any change in the spot on the garage door. I'll try again.
Old 01-30-2004, 07:47 PM
Re: Re: align or aim headlights 99 suburban
OK: Let's make sure we're looking at the right stuff. There are 2 long shafts sticking up above each headlamp. They have external socket fittings. These hold the headlamp assy in place and if you need to replace a bulb, these are the way to get the assy out to do that. The adjustment screws are just a bit aft of these and are about 4-5 inches down in a hole. They take a T-15 torx. The one centered above the assy will adj up & down. In most cases CW will be up and CCW will be down. The other adj'mt screw for left & right is inboard about 6 in's and is just above the inboard end of the headlamp assy. Hope this helps..............Steve
Old 01-31-2004, 08:49 AM
Re: Re: Re: align or aim headlights 99 suburban
ooohhhHHHHH yeeaaAAAHH!!, I see said the blind engineer! So you're telling me I did not need to move the battery to change the headlight bulb a few weeks ago? dagnabit! I can back out the external socket fittings and the entire headlamp assy comes out?
My friends and neighbors thank you for the unblinding advice on the aiming advice, too.
Any advice on my other posting regarding the fuel gauge error? Is there any basic troubleshooting I can do, or is it a slam dunk that the tank needs to be dropped? If yes, I am not going to takle that one.
TF
Old 03-30-2004, 03:13 PM
Switching to vehicle number 2, my 2000 Corvett.
Q1. I also need to aim the headlights on my 2000 Corvette. Can I get the same great instructions?
q2. Also, I just purchased the '00 a few months ago. It has an annoying whine or squeal like a bearing noise in either the tensioner or fan belt. Any history here for likely suspects? It may be the original belt. Listening with my eyes it seems to be coming from the belt tensioner.
q3. And, I am getting ready for my first oil change. Bought a low profile floor jack, but if the lift points are where I think I see them, they are about a foot in from the edge of the car. I am considering buying a 2x10 and using it as a ramp to get the car up enough to get the floor jack in far enough to hit the lift point. I'm obviously no pro, but I do like to do things the right safe way... Are the lift points actually in about a foot and is the an alternative lift technique to get access the filter and drain plug?
Old 09-05-2004, 11:46 AM
agidi agidi is offline
Send a message via MSN to agidi
Smile Re: Re: Re: align or aim headlights 99 suburban
Steve THANKS!
you just saved me alot of work.
I was about to replace the headlights on my suburban and saw they could not be reached from behind. It did not sounded logical to have to dismantle half the front just for bulbs. So I searched the net, and your post came out.
I went back out, laughint and with my tools and bulbs. Job done.
Now I'll align them tonight.
Any suggestion of distance from the behicle to the spotting wall to properly align them? suggestions?
thanks!
greetings from Mexico.
Any tips for aiming headlights and fog lamps? koohead Grand Prix 10 04-25-2004 11:49 AM
Need Help Fast! How do you aim headlights ChristiNate Altima 2 12-20-2003 02:12 PM
how to aim headlights on 03 accord pdqgp Exterior | bodykits | Lighting 2 08-07-2003 10:16 PM
aiming headlights 91civichatch2571 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-03-2003 09:42 AM
Aiming Headlights? m3kidds Exterior | bodykits | Lighting 6 08-28-2002 10:44 AM
