How to hook up Apexi V-tec controller to 98 prelude?
my girlfriend bought a used Apexi Vtec controller and fuel enrichment controler (same unit, has a blue front) off some guy and of course i have to wire it up for her. she has a 1998 prelude with the H22A and it is a 5 speed. does anyone have any diagrams? I dont even have a stock diagram or any paper work for this unit, so guys help me out. its cold out so I dont want to be outside for to long.
thanks Kyle
[url=http://www.automotiveforums.com/vbulletin/showthread.php? 1995 Honda Civic EX -Integra B18B1 LS engine -Turbocharged -Rear disk conversion -Many mods ![]() Cheak out my civic (cardomain) Easly got 10k into this car with everything and it still looks like a POS |
http://tuning.japancar.ru/instr/apex...onics_vafc.pdf
or http://tuning.japancar.ru/instr/apex...ics_vafcII.pdf or get a pro to do it and get it rolling road tuned - you can seriously break your car if you get it wrong, or set it up with bad settings |
Re: How to hook up Apexi V-tec controller to 98 prelude?
yup
Power is Nothing without Control #464 NBP ITR Comptech Sports Intake+ Ice Box, AEM FPR, AEM fuel rail, Nology wires, Greddy Iridium plugs, DC sports 4-1 SS header, Apex'i N1 Exhaust, Apex'i VAFC II tuned [email protected] ![]() " Stop dreaming the life, Start living the Dream..."
links are dead...
Not-named-yet: 2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl Claudia (traded-in): 2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2 R.I.P. Jessica 1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter |
Links are live... need adobe acrobat reader (& some patience if you're on a modem connection!)
I downloaded these instructions from this site and then gave them to an auto electrician who fitted the VAFC I'm getting mine rolling roaded next week so watch this space! (I have had a play and setting it leaner than normal seems to make the car quicker - but setting it too lean will melt your pistons so be careful! - I have also noticed that the vtec controller is a bit fussy - it makes a wierd noise if you set it at say 4500 RPM - between that rpm and factory vtec change point it just sounds odd - I am definitely thinking that this is a sophisticated bit of kit that needs professional setup - but if you are out to save a few quid and you are comfortable with a bit of soldering then you can probably fit it yourself without going too far wrong) I will post more to this board when I have had it tuned and let you know if it is worth doing and doing well, or worth flogging on ebay to the highest bidder !!! P |
More info...
Ok guys... more info - I have run it by a guy who sets a lot of these things up... he took my car out with me and had a play with it.
He suggested that the main gain from this bit of kit is the VTEC control part of it (moves the VTEC point down so you improve acceleration) - mine is set to L>H 4800 H>L 4700 which seems to be about the optimum setting. Any lower and you seem to lose power when the vtec kicks in (you might be ok with setting them 100rpm lower - see how it feel) The second part is the fuel control: What he said with this is that you need to either get it on a rolling road with a CO2 detector in the exhaust and look to get a 3% reading at full throttle, high RPM (this is for a car with a cat replacement... if you still have a catalytic converter on the car I would check what figure you are looking for because it will be different. The other way is to get a fuel/air mixture gauge fitted, then you can set the fueling up accurately with this (not sure exactly what ratio you would be after - I'm sure you can find out though) Just one other thing though... this guy said that on UK cars, the VTEC controller part of it doesn't actually work 9 times out of 10 (this might explain why these things turn up on ebay all the time!) Hope this helps you out! |
