Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 01-27-2004, 09:00 PM
jimyndana jimyndana is offline
Send a message via AIM to jimyndana
Smile Wipers won't 'park'
We have a 97 Trans Port. When my wife went to back out of the driveway. She hit the wipers to make one swipe across the window (no ice just water) The wiper came out of 'park' and rested on the windshield not to mave again. I went to the junk yard and picked up a new motor assy. After swamping the assy the new one will run the wipers but will not 'park'. Everything else seems to work right. Did I do something wrong during the install? Is there some kind of a switch that tells it to park? I feel as if I don't have something right about the install (even though I replaced it the same as removed)
Old 01-28-2004, 03:16 PM
Thumbs up
OK here's the deal. So everyone will know there is a 'park alignment tab that has to be aligned with the wiper motor. I talked to a GM tech and he explained how it worked. With walked me thru a quick fix. THANKS
Old 04-08-2004, 01:04 AM
tigerfreak36 tigerfreak36 is offline
Send a message via AIM to tigerfreak36
Re: Wipers won't 'park'
hi was the motor hard to change? i have a 94 lumina apv same thing as the transport and the wipers will work if i hit the motor thanks much Rick
Old 04-30-2004, 09:25 AM
TaiN's Avatar
TaiN TaiN is offline
Hello, I have a 94 Lumina APV myself with wiper problems. What I did first was run a ground wire to the motor. That worked for about 2 weeks. Then I found a pulse board on ebay and replaced that and now it works like a champ. The motor is held on with 3 bolts and the pulse board in on the motor. Hope this helps!
Old 05-31-2004, 12:23 PM
echerr echerr is offline
GM had several circuit boards (used on many of their vehicles like pick-ups and vans) that had cold solder connections. I fixed them once, but it seems that the boards had some type of contamination. This is just me talking though; I work for a circuit board manufacturer so I’m familiar with them. The easiest thing to do is to replace the circuit board, which controls the wipers. They cost $35 at Full Service Auto Parts and it takes only ten minutes to replace.
Old 04-22-2005, 07:51 PM
djwright4341 djwright4341 is offline
Having same problem with my '97 Sunfire. I'd like to check the park alignment tab and everything else, but I can't get at the wiper motor under the plastic cowl that covers it. Is there some trick to getting the wiper arms off? I removed the nuts at the base and the arms are supposed to just pull straight off, but they won't budge. I scratched the paint on either side trying to pull them off with pliers but was afraid I'd break something if I pulled too hard. I wiggled and pulled and shook and even cussed at them but they wouldn't move. Any ideas would be appreciated!
Wipers won't squirt & HVAC won't work marksgt Grand Prix 3 09-23-2010 10:36 AM
hatch won't lock, back wiper won't work idemoran Rainier 1 02-14-2008 11:59 AM
Wipers won't turn off!? onikoroshi_1 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 07-31-2003 12:22 AM
Winshield Wipers won't turn off fkester General Discussion 2 11-09-2002 03:31 PM
Windshield wipers won't turn off!!! fkester Engineering/ Technical 0 04-16-2002 10:25 AM
