Old 01-27-2004, 07:48 PM
carlasfxdl carlasfxdl is offline
Send a message via AIM to carlasfxdl Send a message via Yahoo to carlasfxdl
97 Blazer probs!!
I have had nothing but problems with this vehicle since the transmission went. There was no 2nd,4th or Reverse. Had it rebuilt, along with a tune up and various other odd items. Took it to inspection and it failed emissions. Took it to a mechanic who had a computer. He said that due to all that was done previously the computer in the truck didnt register everything and to drive it for awhile. Then the heater died, had that fixed. Then the engine light came on. Then the truck would only start when it felt like it!! Didnt make a difference if it was cold or colder!! It started when the temp was 21 but not when it was in the 30's and vice versa. I would turn the key and all the dash lights would come on, but nothing else. Took it back again, and now there is a P1300 code that has no meaning!!! They cant find anyone that knows what it is. Any suggestions???
Thanking you in advance .. and hoping the darn truck starts in the morning ..
Old 01-27-2004, 08:05 PM
comp comp is offline
if mine the first thing i would check, are all electrical conections good,
and cleaned ,,do you know the past history of car??? lotta miles, rental,
etc, are a lot of parts on the truck not original( wreak rebuild) do you
have a second car
Old 01-27-2004, 08:16 PM
Re: 97 Blazer probs!!
have a second car
Well, according to the mechanic who has had it on his computer, all is fine except for this P1300 code and the engine light on!! The truck is over 100,000 miles, has had all of the other work mentioned in the other post but only starts when the spirit moves her!! And yes I have another vehicle .. however I need to leave that home for my daughter. I cant ride my bike with all the snow and ice!!! lol
Old 01-27-2004, 08:24 PM
Bronco2 Bronco2 is offline
I like elec. probs but I need more specifics-you said the dash lites come on but nothing else-does the truck not turn over at all or does it turn over and not start?
i don't have anything rattling around in my head right now , there are
some factory tech's that check in, be carefull on the bike in the snow
Old 01-28-2004, 09:03 AM
Unhappy Re: Re: 97 Blazer probs!!
Bronco,
On the days she decides not to start, and that has not been consistant with cold weather, the key turns all the way, all the dash lights come on ... and nothing .. no whine .. no cranking .. nothing ... just dead silence!! The computer that the mechanic had it on showed a P1300 code that he knows nothing about other than it may have to do with the ignition.
Old 01-28-2004, 04:05 PM
Questions sometimes bring answers::: is there a/or a few connectors
around the neu. safety switch
Old 01-28-2004, 04:38 PM
I think you have 2 seperate problems-the turning over part is not hooked into the ECM to set a code.The best way to diagnose this problem is when the truck doesn't turn over-anything else is guess work. Do you do any of your own work? I'm assuming the truck will turn over when it feels like it without a jump start,so we can probably eliminate a battery problem. Connections and cables are also a possibilty. Try starting it with the headlites on and watch the headlites-if they go out this indicates a problem on the pos. cable side. Bad starter solonoids usually at least click even if they don't power the starter. Since you hear nothing I'm thinking the solonoid is not getting power to engage. This leaves 2 likely areas-either the ignition switch itself or the neutral safety switch (auto trans) or clutch safety switch (manual trans) This is about the best I can do without hooking the meter to it. Get this fixed,clear the code and drive it untill the lite comes back on and go from there. Hope this was some help.
Old 01-28-2004, 09:15 PM
Just exactly where would that switch be??
TIA ... Carla
Old 01-28-2004, 09:20 PM
Other than checking all the fluids and replacing what is necessary I do none of the work on the truck ... lol I had recently put in a new battery and at that time they checked out all the connections. It is an auto trans but I do not know where the switch you are speaking of is. So far this guy wants to replace the catalytic converter and the ignition, which from what I understand is also going to cost me a lot of money. Someone had suggested disconnecting the battery to see if the computer would reset itself ... what do you think of that idea??
Old 01-28-2004, 10:09 PM
97blazerct's Avatar
97blazerct 97blazerct is offline
Send a message via AIM to 97blazerct
oh so familiar.. lol. I got my 97 Nov 4th.. On Nov 14th the starter blew.. got that fixed then on dEc 5th the tranny blew. also lost 2nd overdrive and reverse. got it fixed and on dec 24th the tranny blew once AGAIN. got that fixed and then there was NO HEAT. ends up its probally the thermostat and i have a new one buts its been TOOOOOO cold to change it. Then after all of that crap my 4x4 wouldnt work, ends up a vacuum hose had accidentally came disconnected during the 2nd tranny rebuild. Then after that was fixed i got this LOUD whining noise that only happens once in a blue moon but i havnt the FOGGYEST what it is...
nothing but problems. i love her though...
fords.. drive a chevy
My 1997 Chevrolet Blazer LS 4x4:
http://www.sounddomain.com/id/chevy4x4girl
Check out the pictures of her! Sign the guestbook and rate her good!
Old 01-28-2004, 11:29 PM
Disconnecting the battery may clear the code,but it has nothing to do with "turning over" problem.A bad cat. will not affect the "turning over" prob. The 1300 code is an ignition code,but the ignition won't fire unless the engine turns over,which it doesn't do. The neutral safety switch is on the side of the trans where the shift cable hooks up. The purpose of this switch is to only let the truck start in park or neutral. If the internal connections get weak,it won't send power to the starter.Next time it doesn't turn over try starting it in N and/or pull the shift lever between P and 1 several times. If that gets it turning over the probs. in the switch. Just so you know I am a ASE certified Master Auto Tech,not trying to down your usual mech. and you may have other probs.,but I do not see the parts he wants to replace relating to the major problem .And if 97blazerct reads this,I drive a Ford.They all (Chev.,Ford,Toyota,etc.) burn gas,they all break down.
Old 01-29-2004, 08:10 AM
97blazerct's Avatar
haha, at least my truck will always look pretty while doing do ;-) lol jus kiddin.
my truck isnt too bad on gas though.
-Christine
Old 01-29-2004, 08:43 PM
Bronco,
I have actually never used this mechanic before, he is near work and thought I would try him. I will ask him about the neutral safety switch. If the truck is starting sometimes would that mean that the 1300 code is erroneous? I am just trying to get the damn thing through inspection without spending more than I already have.
TIA ... Carla
Old 01-30-2004, 08:22 PM
Carla- the 1300 could be erroneous(my new word of the day)- I don't know the emissions laws in Jersey, but I would disconnect the battery for 12 hours before you take it in. Sometimes,when there is electricty going places it shouldn't, the ECM will set a code,but like most systems,it won't give a specific code because that fault is not in the programming. I think I would have to pass on the guy close to work,it seems that want to replace quick money parts without getting to the core of the problem. The more I look at this it seems to be a ground problem.Do you have a auto electric shop nearby? Question-what does lol mean-I understand TIA, help me on this one,I see it a lot.
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 09:35 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 10:45 AM
Blazer Probs jimmyg8947 Blazer 2 12-24-2004 09:16 PM
95 Blazer probs. just replaced EGR valve...please HELP!!! Onedose24 Blazer 9 03-11-2004 02:44 AM
