Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 01-26-2004, 11:03 AM
kevin9333k kevin9333k is offline
Shift Solenoid A and B Circuit - Electrical
I have a Denali 2002 and noticed some slow down and a light would come on in the car to "check engine". I had a friend do a test with the OBD II and it showed 5 faults:
1) PO740 - TCC Circuit malfunction
2) PO753 - Shift Solenoid A Circuit Electrical
3) PO758 - Shift Solenoid B Circuit Electrical
4) PO785 - Shift/Timing Solenoid Malfunction
5) PO860 - Manufacturer Contrl. Transmission
Shall I replace the Shift Solenoid A & B? If so Do you know where this is located on the SUV?
I am assuming if this is replaced it will probably correct the others.
Thank you,
Kevin
Old 03-06-2004, 10:05 AM
mjcotton mjcotton is offline
You should have more diagnosis done before replacing any solenoids. I own a tranny shop and often find this many codes can indicate a number of different things.
If you have access to an OBDII scanner. Clear all the codes, drive the Yukon and see which code comes back first.
If you're willing take your Yukon by a reputable tranmission shop and have them check it to determine the root cause of these codes.
Good luck
tcc solenoid problem 95 k1500 4l60E coreman30 C/K 6 01-26-2011 02:18 PM
95 k1500 wont shift into 2nd.. found melted solenoids coreman30 C/K 9 01-18-2011 04:24 PM
92 Accord hard to shift in and out of park rango25 Accord/TSX/Accord Hybrid 5 11-12-2009 04:57 PM
Replacing Shift Solenoids and have a question Grandpa's Aurora Aurora 4 05-23-2006 12:41 PM
Shift Solenoid and O2 Sensor '97 Metro Ms.Alisha Metro 5 01-07-2006 12:17 PM
