Old 01-26-2004, 11:22 AM
hardywang's Avatar
hardywang hardywang is offline
Send a message via ICQ to hardywang
Crankshaft Position Sensor Question
Hi guys,
In the last 2 weeks, my 97 GTP has something abnormal.
  • Tachmemter will die sometime while car was running, it happened several times.
  • I had 2 times, when I fully stopped before trafice light, check batter and check engine oil lights on, after then car could not move any more. For the first time, I restarted car, everything turned normal. For the second time, car could not start again. A guy nicely helped me to push car off road, and then I tried again, it started!!
I posted in some other forums, some guys suggested crankshaft senor is gone, and battery/alternator is bad.
Last Saturday I sent it to dealership, they scanned to report Crankshaft senor was bad, and I had it replaced.
Now I have some questions
  1. does only this sensor cause these problems?
  2. I tested battery while car was off, reading is 12.7V, I think it is normal; I started car, the reading is 15.08V (should it be 14.4V), is it too high? How can I tell if alternator is really good or bad by myself?
Thanks for any suggestion!!
Old 01-26-2004, 12:58 PM
fast98gtp's Avatar
fast98gtp fast98gtp is offline
Send a message via AIM to fast98gtp
Re: Crankshaft Position Sensor Question
on my 98 it reads aroung 15v too. it's been like that for years. i wouldnt worry about it. i havent had any problems with it being that high.
Old 01-29-2004, 04:27 AM
JoeJoe231455 JoeJoe231455 is offline
Re: Re: Crankshaft Position Sensor Question
Those are the classic symptoms associated with the cps.
You should be good to go now...
Old 01-29-2004, 01:46 PM
jcas1411 jcas1411 is offline
That is a good sign. You have a good altenator. Under load High beams on, stereo blasting it may pull down to that 14V. Crank sensors when bad do cause havoc.
crankshaft position sensor question cabits Intrigue 13 12-13-2011 06:41 PM
Crankshaft position sensor GregGP Grand Prix 1 03-25-2010 05:33 PM
Pontiac GA Cam position sensor LOCATION ? cigars99 Grand AM 6 07-11-2009 11:30 AM
Crankshaft Position Sensor Question ricknwi Intrigue 1 10-25-2007 07:44 PM
Another Crankshaft Position Sensor Question hoofan Grand Cherokee | Grand Cherokee SRT8 9 04-19-2006 07:45 PM
