Old 01-26-2004, 09:56 AM
uuj uuj is offline
Fuel filter/injectors
Where is the fuel filter on the 2002 Chevy Tahoe located at? How often do the fuel injectors need cleaning. Is this something Jiffylube can do or is it a trip to the dealership???
Old 01-26-2004, 03:45 PM
Redonthehead Redonthehead is offline
Dunno for sure, but its probably inside the frame channel directly under the drivers seat. Probably change it every 30K. Injectors - surely they don't need to be cleaned until at least 75K
Old 04-08-2004, 03:07 PM
toadload toadload is offline
Re: Fuel filter/injectors
I've got a 2003 with the Alternatie Fuel 'Z' vin 5.3 V8
and You can only but the Filter from the dealer (doh) any thoughts on diy and what tools ya need? Some non-standard tool(size) needed ....
Old 04-21-2004, 01:42 AM
aero246 aero246 is offline
Ok here's the deal on the 2003 (Z) vin Fuel filter. I just changed mine. I also did have to buy the filter from GM. You will need a special tool as standard fuel line disconnects will not work. It's a $40 piece of plastic that looks like a fuel line disconnect however finding this tool is next to impossible. i found the number in my Service Manuals which bought from Helm Inc. It's a J something. You can only buy it from this place. http://www.spxkentmoore.com/
You have to call the number and give them the tool # you want. I will post the number in the morning when I get home from work so you can buy one if you want. Otherwise the dealer will have to change your filter for you as there is no other way to do it.
Old 04-21-2004, 09:43 AM
Here is the part # as promised to the above mentioned web site. It is "J-46363 Fuel Line Release Tool"
Hope this helps.
Fuel filter changeout process DennO Ranger | Courier 3 01-02-2011 01:50 PM
Fuel Filter Replacement CCMphysician General Discussion 4 01-15-2010 04:27 PM
1982 E-150 Fuel filter HELP Evilfonzie Econoline 2 12-18-2009 11:48 PM
'85 Caprice - More than 1 fuel filter? caffeineaholic Caprice 5 07-12-2009 09:09 PM
fuel filter/injector?? tsi9187 Eclipse Problem Diagnosis 0 01-02-2005 07:59 PM
