Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-08-2009, 09:29 AM
caffeineaholic's Avatar
caffeineaholic caffeineaholic is offline
'85 Caprice - More than 1 fuel filter?
Hi all, I've been wondering for a long time if my '85 Caprice has more than just the fuel filter on the carb. If memory serves I read in my Chilton manual that there may be an inline fuel filter as well as the fuel filter in the carb. Is there one in the fuel tank as well? Or perhaps just a screen to keep large particles out?
Thanks for your help!
1985 Caprice 305 5.0L
Rochester Q-jet Carb
1985 Chevy Caprice small-block V8 305ci (5.0L) - 4-Barrel Q-Jet (E4ME) - 700R4 - 115k+ mi. - resonator and A/C components deleted.
Driven in severe weather most of the year (Arizona 100+ degrees during summer heat or in wet weather especially in harsh monsoons). About 30/70 highway/city driving.
Old 07-08-2009, 06:41 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: '85 Caprice - More than 1 fuel filter?
There is a screen on the fuel pick up tube in the tank.
I don't think there is another filter except for the one on the carb.
Chilton manuals can be so misleading sometimes...
Do yourself a favor and get a factory service manual and ditch the Chiltons..
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 07-08-2009, 10:23 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The inline filter is present on the '85 equipped with the 4.3 liter FI engine. The V8s all had the filter in the carb.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-09-2009, 11:06 AM
j cAT j cAT is offline
the fuel filter is in the carb,,this filter needs replacing often because the fuel tank is rusted,,being this old...the filter is very small as well...adding a filter larger on the input to the carb is possible to reduce debris from entering the small filter in the carb...
using a metal pre-carb fuel filter is a good way to keep the carb from getting contaminated..
replacing the carb filter you will need a new gasket ,,the debis will be in the center of the filter...care must be taken when you remove and install the fittings...be careful not to crossthread the fittings...use of a LINE wrench is recommended..
Old 07-09-2009, 01:35 PM
Thanks for all of your input, I plan on getting a factory service manual in the near future... I have been a bit disappointed with the Chilton's manual I have. I may also check the gas tank since it has never been looked at before (23 years).
Old 07-12-2009, 09:09 PM
RageCage RageCage is offline
Caffeine,
I have the 85 also. My gas tank was showing some rust on the outside, so I rubbed an oily rag all over it ( used used motor oil) a year ago, and it has stopped the rusting. (From the outside, anyway). Also, I installed an inline see-thru plastic filter about 10 years ago, since the carb filter is a real PITA to replace. I just replace the plastic filter every couple of years now. Much easier and quicker.
RC
Tags
filter , fuel
