Old 01-26-2004, 06:57 AM
gobiewankenobi gobiewankenobi is offline
Question EECS Incorrect Purge Flow?
What is this caused by and how can it be fixed?
"P0441 Evaporative Emission Control System Incorrect Purge Flow"
Could it be as simple as replacing the PCV valve?
Thanks.
Old 01-27-2004, 12:54 AM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
Re: EECS Incorrect Purge Flow?
Thanks.
No. EVAP uses a vacuum to draw 'fumes' out of the plenum area into the charcoal cannister. Id look for a burned vacuum line somewhere or depending on system, a bad check valve. The is pretty much a generic OBD2 code you gave, can you be more specific on what it came from?
Old 01-27-2004, 09:01 AM
The code is from a 1998 Hyundai Elantra.
I'm in the process of trying to find out where exactly the purge solenoid valve is and the canister so I can check it.
code P0441 EVAP incorrect purge flow 96tsport Trans Sport 6 07-07-2009 12:30 PM
p0441 incorrect purge flow. hundahunta Impala | Impala SS 4 12-31-2006 07:24 PM
Incorrect Purge Flow nolan19 Grand Prix 1 02-08-2005 05:24 PM
1999 prism code P0441 purge flow rate johnholl General Discussion 0 07-15-2004 11:28 AM
MIL code 92 EVAP Improper purge flow GSR Integra 0 06-26-2002 11:08 AM
