Old 01-25-2004, 11:18 PM
a2b2003 a2b2003 is offline
Help for replacing a thermostat
Hey, I'm getting ready to replace the thermostat in my 96 4.3 S10... I want to make sure I'm doing this right so I'm going to run my steps by you guys first so that you can tell me if I'm doing something dreadfully wrong...
1.) Let car cool
2.) Unscrew bolts on thermostat
3.) Take old therm. out and put new one in
4.) Put the housing back on... and done
I feel like I'm missing a step here tho.....
Also, how bad is it to put non Dex-Cool Coolant into the coolant tank?
Old 01-26-2004, 08:43 AM
RKINGII RKINGII is offline
Re: Help for replacing a thermostat
I just changed mine a couple of weeks ago. I had to take off the serpentine belt, in order to get to your step two. It's a little cluttered there. Two gaskets, one o-ring type on the therm flange, and a regular one on the housing flange. I used gasket dressing on the second one. Take care in torquing the housing back on. DO NOT, I repeat, DO NOT put non Dex Cool coolant in there unless you completely flush out the system. You cannot mix the two different kinds of coolant, without disasterous results. Buy the Prestone flush kit. Basically a connection you add to the heater hose. It works well, just follow directions. Good Luck
Need help for replacing valve cover gasket on 96 GC V8 stanleyeye Grand Cherokee | Grand Cherokee SRT8 0 06-25-2007 11:02 PM
92 Cav. overheated replaced thermostat now dies for no reason gargamel34 Cavalier Problem Diagnosis 0 03-19-2007 08:38 AM
please help. boyfriend replaced thermostat and now won't start nine99 Accord/TSX/Accord Hybrid 4 03-10-2006 07:11 PM
help replacing thermostat scarr133 Venture 8 12-05-2005 02:32 PM
Factory stereo stolen! - Need help for replacement slaeyer Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 02-17-2004 10:35 PM
