Old 03-02-2006, 05:41 PM
nine99 nine99 is offline
please help. boyfriend replaced thermostat and now won't start
I have a 1990 honda accord, the thermostat was bad and my boyfriend replaced it. after he finished, the car kept dying and restarted after switching it off. now, the car won't restart at all. i suspect he knocked something about while he was replacing the thermostat. could someone please tell me what might be the trouble? it was fine before that and I had the distributor and rotor replaced just 2 months ago.
Old 03-02-2006, 06:20 PM
Bruce Hunt Bruce Hunt is offline
Re: please help. boyfriend replaced thermostat and now won't start
First of all is the check engine light coming on? I would check it for a code using the jumper method that is available on all hondas. I have to tell you to check the wires and the wiring on some of the sensors located around the area and I wouldn't rule out the possibility that you may have disrupted the life of some component when working in the area. For instance, the internal coil on the car could be the culprit. Have you got spark at the plugs? Always start with spark and fuel.
If I was able to help you, that made my day; if you offered assistance to me, I thank you so very much! Either way, have a great day! Now own 4 Accords and 2 Civics. Love Honda!
Old 03-02-2006, 06:25 PM
thank you for the reply. the check engine light is not on.
Old 03-02-2006, 08:36 PM
phantastic1 phantastic1 is offline
if i can remember correctly...i think there may be a ground on the thermostat housing....have him double check to see if thats loose. had the same problem w/ my friends civic...it would start then shut off...we rechecked the grounds...and found the loose ground by the thermostat.
Old 03-10-2006, 07:11 PM
LILT23 LILT23 is offline
there is a ground wire on the bottom bolt and that should fix the problem if not the dis got wet inside
