Old 01-25-2004, 08:23 PM
nusch nusch is offline
transmission
I have a 94 5.7L blazer and it has no power. It starts out in third and won't shift out of it. Reverse works fine. No codes have come on but I am going to check them and make sure. I read in another post that the ecm sets it in third when there is a problem. It came on gradually and would only do this when it warmed up. Now it does it when it is hot or cold. I am going to check out the VSS even though there is no problem with my speedometer. Does anyone know what would do this?
Old 01-25-2004, 11:16 PM
Re: transmission
Now that I realized that the code can set wothout turning the service engine soon light on I pulled the codes off and found that code 81 was set. How do I go by fixing the 2-3 shift solenoid?
Old 01-26-2004, 01:44 PM
Re: transmission
I got under the truck today and tried to find the yellow/black wire that is supposed to go to the 2-3 shift solenoid but could only find the same color that goes to the temp sensor. Does anyone know where the solenoid would be on the transmission?
Old 01-28-2004, 06:57 PM
grimesjm1 grimesjm1 is offline
Send a message via AIM to grimesjm1
Re: transmission
your best bet would be to get on ebay or something and buy a pamphlet on rebuilding it. they are pretty cheap and will tell you where your solenoid is.....
Old 01-28-2004, 08:56 PM
billy2 billy2 is offline
Re: transmission
Those solenoids are inside the pan attached to the valve body.. There is a rather large harness going to the tranny, the wire is in it. If you drop the tranny pan you will see the solenoids on the sides of the valve body. I think they can be changed without removing the valve body. You will see the wire colors going to the solenoids inside. I think those solenoids cost about $50+ each.
Mustang Transmission part 2001 lawg8r Mustang Problem Diagnosis 1 04-13-2009 04:24 PM
Changing Transmission mkcody88 Accord/TSX/Accord Hybrid 2 04-05-2009 01:50 PM
h22 sh transmission used as a regular transmission h22 Prelude 1 07-31-2004 11:32 AM
?Transmission Fluid Needed for Manual Transmission? 85BlueGTI Golf 1 05-31-2004 08:21 PM
1988 Z24 Transmission problem, torque converter wont lock after transmission change Dale24 Cavalier 4 01-23-2004 02:29 PM
