Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 01-25-2004, 06:33 PM
kanekz kanekz is offline
95 Cutlass Supreme Overheating
Its a 95 Cutlass Supreme 3.1L
The temp gauge was rising a few days prior. Then it overheated yesterday. When the engine is at normal operating temp., no coolant is running through the upper radiator hose. Just the bottom one. Can it be the thermostat is stuck closed or something to do with the water pump?
Sometime the low coolant light would flicker on and off even though there was enough coolant. I read there was a TSB on this though.
Old 01-26-2004, 03:56 PM
Re: 95 Cutlass Supreme Overheating
Well took it to a shop and they said the raidator is bad, needs to be replaced. They said there was a leak on the raidiator, but I saw no such kind before I took it to the shop. What do you guys think? Shady business going on here?
Old 01-29-2004, 11:12 PM
SSANDOZ SSANDOZ is offline
the thermostat is stuck CLOSED OR YOU ARE LOW ON COOLANT NOT JUST THE AMOUNT BUT THE ANTIFREEZE MIXTURE IS IMPORTANT. IF YOU HAD A SLOW LEAK IN THE RADIATOR YOU COULD HAVE THE SYMPTOMS YOU DESCRIBED ASK THE SHOP IF THEY PRESSURE CHECKED IT.
Old 06-24-2004, 11:59 PM
serk16 serk16 is offline
hey man I had THE EXACT PROBLEM with the same car identical! OK if you did currently replace the thermostat then I am positive it is a AIR BUBBLE in there. There are two little areas where you can let the air get out while the car is on, I couldnt do my second release it had to get taken off by a dealer and sucked out! (look out they are tricky..and one of the most least expected problems)
Old 06-26-2004, 01:34 PM
Lightbulb Bleeding Air Out Of Coolant Passages
This Problem Of Air In The Coolant Passages Can Be Trickey And It Is Not Just Gm Products. I Have Seen A 1992 T-bird With A 3.8l V-6 Fried, Smoked, Burnt Up Rod Bearings. Because The "mechanic" Did Not Open The Bleeding Nut On The Coolant Line Which Was Clearly Labeled And In Plain View. What A Waste!!!!! The Problem This T-chicken Was In For Was Blown
Head Gaskets. Real Common Because The Brillant Minds At Ford Thought Putting Aluminum Heads On A Steel Block With A Crappy Cooling System Was A Good Idea Since They Were Mating It To A Real Piece Of Garbage Transmission. Other Than Those Problems It Is A Typical Ford. Made It To 82000 Miles And Now Is Worth More As A Parts Car . Alot Of Fools Out There Like Fords And You Know They Need Parts!!!
96 Cutlass Supreme with Alternator trouble chrisluna Cutlass Series 4 10-05-2009 04:34 PM
96 Cutlass Supreme w/ humming noise coming from under the back of the car chrisluna Cutlass Series 1 09-28-2009 12:11 PM
94 cutlass supreme overheating - please help ednit Cutlass Series 3 12-17-2006 09:26 AM
93 Cutlass Supreme - overheating, low coolant netjunkie2 Cutlass Series 5 08-30-2006 10:18 PM
94 cutlass supreme overheating toeppe85 Cutlass Series 3 07-20-2005 11:32 PM
