Old 01-25-2004, 01:31 PM
VoiD VoiD is offline
Noob primer questions.
I'm about to paint my 350Z body shell into blue.
Now Is it okay to use gray primer? or is white better?
The tamiya instructions shows to paint white after primer, then body color. Is this white coloring necessary for a good finish?
Also when primering, do i need to plug all holes? is primering going to clog them up?
Old 01-25-2004, 01:37 PM
pettercardoso's Avatar
pettercardoso pettercardoso is offline
Send a message via MSN to pettercardoso
Re: Noob primer questions.
First of all, welcome to AF.
Second, you do know there's a FAQ section, don't you?
Give it a good read, THEN post your questions. That particular one has been aswered many, many times.
here you go:
http://www.automotiveforums.com/vbul...ad.php?t=63623
Pedro
Click the picture to check my progress thread:
Old 01-25-2004, 01:49 PM
Yes I read the FAQ..
Just went over it again and I still don't understand the painting white over primer part. Can I use gray primer, paint white over it and use it to paint light colors? Or would I have to go buy a separate white colored primer?
Old 01-25-2004, 01:57 PM
Yes. All colours should be painted over white primer, except for black and grey. These two cover almost anything. The only reason for the white over grey is because the light colours with eventually become darker if you use grey primer. alex wrote a great tutorial on this. check it out here:
http://www.italianhorses.net/Tutorials/paint.htm
Pedro
Old 01-25-2004, 02:06 PM
wow. really helpful with all the pictures.
THANK YOU!!
Old 01-25-2004, 10:23 PM
primera man's Avatar
"P-Man"
You would be far better off buying some white primer.
View All My Models Here.
Old 01-26-2004, 04:36 AM
David_ David_ is offline
white primer u can use practically for anything.... while on topic of priming... i got some like... not fine primer... its the stuff that goes on lumpy.... (for cars, and very large surfaces.) can i use this, and sand off excess lumps. or am i better off using fine primer (which i also hav, but want to save)
