Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-25-2004, 12:31 PM
Merlin02131 Merlin02131 is offline
Send a message via AIM to Merlin02131 Send a message via Yahoo to Merlin02131
NO Overdrive in cold weather
Bulletin # 21-004-01
Group Transmission
Date : Feb 16 , 2001
Overdrive disabled to improve transmission reliability during cold temperature operation
Models 2001 ( BR/BE ) Ram Truck
Vehicles equipped with an RE Automatic transmission , the vehicle was built on or between june 26 , 2000 (MDH 0626XX and December 23 , 2000 ( MDH 1223XX) and the PCM Software level is earlier ( lower ) than calibration 14 for model year 2001 .
Found out last week that in weather below minus 5 degrees F , My 2001 Dodge Ram 1500 would not shift into overdrive on the highway . When I called my dealer ( Jeep by the way ) , they found a bulletin that states that in weather below minus 5 , the transmission will not shift into over drive due to a fluid freeze issue . This is a known issue with Dodge and it is a fluid freeze issue whereby at that temp , Fluis starts to freeze and there is not enough fluid traveling in the trans and thus inturrupting the flow of lubricating oil ( ATF) to the trans overdrive unit . I live in Boston , but usually temps are not at or below zero , although they have dipped below on occasion as they did this year . I was amazed that I could not get the truck to shift into overdrive as the tach went to about 2500 to 3000 rpm without a shift . Not a problem due to the bulletin .
Rough idle during cold weather start mobzs Sierra 1 03-26-2011 12:00 AM
1995 Ram 2500, Cold weather, overdrive goes in and out around 65 mph duenorth1956 Ram Pickup | Ram SRT10 0 12-30-2005 06:44 PM
salty roads, cold cold weather!!!!????? 97claw Engine, Transmission and Drivetrain 4 12-19-2005 08:15 AM
cold weather smoke friendsam B-Series/Bravo/Bounty/Drifter 4 04-03-2004 12:34 PM
window problems in cold weather greekman Maintenance 4 10-22-2001 02:46 PM
