Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 09-09-2001, 04:09 AM
greekman's Avatar
greekman greekman is offline
window problems in cold weather
today it snowed here in denver. depressing. i noticed a problem that i forgot i had. when it is cold outside, and the passenger window is down it has a very hard time going up. never a problem in the summer, but when it gets cold it goes up reeeeeaaaaallllll sssssllllllllooooowwww or it won't even go up. what's the problem? anyway to fix it?
93.5 G20
Life is like a shit sandwich. The more bread you have, the less shit you taste. So go out and get your bread!
Old 09-26-2001, 10:30 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
yeah, me too
Today the high temp was only 50, and when I was putting up my driver's side window, it CRAWLED. I ended up "assisting" it with one hand while pushing the button. I hope by giving this a new post someone will have an idea. I can't find any info on how to fix this anywhere. Please help. It gets cold with the window down!!!!!
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 09-27-2001, 07:54 PM
stoneage_tech stoneage_tech is offline
i lubercated the window tracks with clear lubercateing silicone . it seeems to help it alot up here where it gets to -60f in the winter. the drivers side window used to freeze itself to its window stripping (causeing it to rip the rubber off the front window strip).also check the window track adjustments as if they are out then you would have a harder time running the window up and down .
mike
1996 G20 out of fairbanks alaska
Old 10-21-2001, 05:46 PM
geoff200 geoff200 is offline
I read in a previous post some months back, that replacing the window motors with aftermarket ones solved the problem - anyone got any views on this.
Old 10-22-2001, 02:46 PM
nismo_gt's Avatar
nismo_gt nismo_gt is offline
Stoneage_tech's right, It's a common problem & Nissan used to replace
the window run rubber (under warranty) to cure the problem,
but silicone spray in the rubber will sort the problem out.
Primera GT
Rough idle during cold weather start mobzs Sierra 1 03-26-2011 12:00 AM
Window problems tizzlestick Grand AM 0 09-09-2010 07:20 PM
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 06:13 PM
98 Cavalier Problems--Cold Weather kmcherry76 Cavalier 2 01-28-2004 07:52 AM
