Go Back   Automotive Forums Car Chat > Lotus | Proton > Elise/Elise Tuning
Old 01-25-2004, 11:10 AM
De1337eD De1337eD is offline
Send a message via AIM to De1337eD
engine swap
i know that the lotus elise was made to be light but i want to engine swap with a new more powerfull engine. does any one recomend anything? i just need to know what can fit and what would be best. thanks for your input
-Michael Stone-
Old 03-07-2004, 09:13 PM
DinanM3_S2's Avatar
DinanM3_S2 DinanM3_S2 is offline
Scuderia Kimi
i'd personally like to see what a Honda S2000 engine could do in a US spec Elise, that would be about 50 extra hp, a much higher redline, and about the same weight
Old 03-10-2004, 09:46 PM
pimp_squeak's Avatar
pimp_squeak pimp_squeak is offline
Send a message via MSN to pimp_squeak
google.is a mans best friend...check for specs, weights, etc. you should have no problem finding what you need
Old 03-11-2004, 04:06 PM
feenix z feenix z is offline
Send a message via AIM to feenix z
Re: engine swap
the new toyota 1.8 twin-cam is gonna be in the U.S. spec version, Personally i always wanted to put a second gen MR2 turbo engine in.
"You wanna raise your truck? Why dont you just punch out your teeth and marry your sister while your at it?"
-Pete Hoeker
Old 04-25-2004, 02:51 PM
MR2Driver's Avatar
MR2Driver MR2Driver is offline
Re: engine swap
A 3S-GTE in an Elise would be SCARY
Old 04-27-2004, 08:59 PM
this is true
Scary, yes, but it's not like you don't have the suspension to back it up. Toyota power and the handling and breaking of Lotus, that's some serious Kung-fu!!
-Pete Hoeker
Old 05-03-2004, 11:55 PM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
Re: engine swap
no more scarry than the 3sgte in my first gen mr2
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 05-04-2004, 08:08 PM
wow
in your gen 1? Lets face facts, that engine makes good power in the second gen. All i can say is, "you brave, brave man."
-Pete Hoeker
Old 05-13-2004, 04:56 PM
nbw nbw is offline
id like to see one of those nissan sr20det(sp?) engines in one. turbocharged, and aluminum block. lightweight yet potent. :]
Old 07-12-2004, 01:15 AM
SmoothShafi SmoothShafi is offline
Re: engine swap
They should've kept teh Integra Type R engine in it like SunSpeed did while importing it in for the last few years. 195 hp, 9000rpm. Oh well.
Old 07-12-2004, 08:16 AM
drunken monkey's Avatar
Razor Sharp Twit
Re: engine swap
.....why do so many people think that they know better than the guys at hethel....?
AF's Guidelines
Read them.
Old 07-21-2004, 01:01 AM
analogvoid analogvoid is offline
Send a message via AIM to analogvoid
Re: Re: engine swap
Not only would the elise be lightning-quick.. it would be ungodly tail heavy. The weight on a 3S-GTE is enormous compared to the stock 2ZZ-GE. One is an iron block (3s) the other is aluminum and other light materials..
Old 07-21-2004, 01:08 AM
kman10587's Avatar
kman10587 kman10587 is offline
Send a message via AIM to kman10587
Re: engine swap
I don't think you want forced induction in a car like the Elise. The best options were the Celica GT-S motor and the Integra Type R motor, and they chose the Celica GT-S.
Old 07-21-2004, 10:57 AM
Razor Sharp Twit
Re: engine swap
various guys have tried to fit different things to the old k series 1.8 and most of them, while did increase power and performance, lost the knife edge fine handling of the elise.
(and then hethel released their own high power versions which once again showed them how an elise should be like....)
the best case where someone fitted a totally new engine in there was a german company who's name escapes me, who used the twin turbo from the old audi S4.
BUT
it wasn't as simple as that.
they also manufactured larger, stiffer, stronger more downforce clamshells front and rear,
as well as a total overhaul of the suspension.
result, an elise with 200mph potential.
you ain't gonna be able to do thet in your garage...
and it isn't cheap.
Old 07-21-2004, 12:46 PM
Yah, i'm sure there are plenty of options for motors to put into an elise if you want it to go fast in a straight line. But that's not the car's purpose at all. That thing is set up to corner!
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
