Old 01-25-2004, 09:34 AM
chinchanwoo chinchanwoo is offline
2003 S10 starting problems
Have a 6cyl 4.3 s10 which runs great....except a couple times now if I leave it outside for a few hours in the cold (like -25c) when I goto start it I get nothing. All the interior lights come on but the truck doesnt even try to start...it just bings at me with the service engine light on...if I keep trying after about a minute it'll just start and give me no more trouble. Obviously not the battery...could say it was the cold but it didn't even attempt to start and then out of nowhere it starts like it never had a problem. Any ideas would be great thanks.
Old 01-26-2004, 10:47 AM
Rishkaan Rishkaan is offline
Re: 2003 S10 starting problems
Check all your battery connections first, make sure they are connected tightly, especially the one for your starter, have you replaced your started or is it OE? Your starter solenoid may be going bad.
Good way to tell this is you got power and you get no response then you keep tring and evetually you get started, as you said already, this is an indicator that the starter solenoid is going bad.
Old 01-26-2004, 05:04 PM
Thanks for the response...I figure it would have to be with the starter...would the solenoid be affected by the cold if its going bad?
Re: Re: 2003 S10 starting problems
Old 01-26-2004, 10:20 PM
Not really, thing is if there is no clicking sound when you try to start it then its the solenoid. If there is a click then its just the gears inside the starter. They just go bad kinda like a battery, one day it works the next it wont. Hope this helped man.
Old 01-26-2004, 10:41 PM
Actually it just happened again tonight and I noticed there is a click when I turn the key and if I turn the key slowly over and over it'll start up...starter it is. I appreciate all your replies, they've been a big help.
Old 01-26-2004, 10:43 PM
Np man anytime.
96 S10 Ignition/Starting Issue fmhsgrad96 Problem Diagnosis 5 05-25-2012 08:19 PM
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
2003 s10 transmission problems burk4200 Problem Diagnosis 6 03-30-2009 07:07 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
S10 Starting problem-lemme explain hexed775 S-10 9 11-16-2004 07:48 PM
