Go Back   Automotive Forums Car Chat > Mitsubishi > Outlander
Old 12-30-2010, 10:53 AM
trobious trobious is offline
Power Window Failing
I have a 2006 Outlander. My driver door window is going so slow it is almost stopping. I am taking the door apart today to lubricate the track.
Has anyone else experienced this? If the lube doesn't help, I will have to order a new motor unless someone in here has another suggestion.
I will keep you all "posted" hehe.
Old 01-05-2011, 04:17 PM
Re: Power Window Failing
I took the door apart and sprayed silicone all along the side tracks that extend out into the window frame and I also sprayed the main track that runs down the middle of the door (on the inside only). There were no immediate results, but after a few days, it seems to have sped up the window.
Unfortunately, I believe this was too little too late because it is still pretty slow. I have ordered a refurbished (or rebuilt) motor and will update this post once it arrives and I install it.
I ordered a used one because new ones are $400 after tax. The used one was only $120 (plus duty, if that was not already included - I live in Canada and ordered from the US).
Old 01-05-2011, 04:21 PM
danielsatur danielsatur is offline
Also try cleaning and RainX on both sides of window, seem's tobe less resistance.
Old 01-05-2011, 04:28 PM
Thank you, I will also try this and let you know if it helps. I should time the window before and after
Thanks again,
T
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
power windows stopped working - 2002 Mercury Mountaineer hoehring Mountaineer 2 01-18-2010 09:25 AM
Power Windows Elec Prob. Please help!! dlane85 Corsica 1 07-29-2009 10:37 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 06:13 PM
98 power window express down problem fliplover Monte Carlo 1 04-03-2009 11:48 AM
Tags
motor , power , slow , window
